Results 1 to 8 of 8
    Jul 2010
    Brisbane
    143
    Default Wiring a Betts Appliance motor
    I have this Betts motor that the previous owner had running a grinding wheel... it has only 3 wires coming from the motor.. red , black and white.
    the fellow used only the red and black and snipped the white one.
    Although it runs, it does not always do so in the same direction !!!... sometimes it sits and hums .. There is no capacitor or centrifugal switch fitted.
    7,189
    What's your question(s) ?
    I'll take a guess?
    The fact that it sometimes sits and hums (if you leave it doing that too long it will cook the run coil) suggests the start coil is not hooked up and that's what the white connection is probably for. The start coil usually has a cap in series to generate the phase shift needed to start the motor.
    Being an open frame motor it's designed to be inside an appliance so it should really be enclosed and then if it doesn't have one it will need a fan.
    Jul 2010
    Brisbane
    143
    Thanks BobL...
    3 things...
    1.. What size cap would I need ?
    2.. Will I need a Start or a Run Cap ?
    3.. White wire to one side of the Cap... but where do I connect the other wire to ?
    As for cooling...It has a fan on either end of the rotor... should be OK as long as I position the vents downwards ..
    7,189
    Quote Originally Posted by kenny_10 View Post
    Thanks BobL...
    3 things...
    Humm . . . . I'm not comfortable in responding to these questions - I'll leave it to someone else if they wish to take the risk.
    Jul 2010
    Brisbane
    143
    Thanks BobL... I understand.
    Jan 2004
    Mackay North Qld
    6,446
    DISCLAIMER
    No liability is accepted by MetalWork Forum's administrators
    or moderators for advice offered by members posting replies
    or asking questions regarding electrical work.
    We strongly advise contacting a Licensed Tradeperson for all electrical work.
    WARNING
    Information supplied within posts is not to be considered as detailed formal instructions to complete a task.
    Members following such information do so at their own risk
    Updated by Grahame - 29-9 -17 6.46 PM
    Jul 2006
    Athelstone, SA 5076
    4,258
    10mfd or thereabaouts
    6,475
    Hi Kenny,
    Have you contacted "Betts" ?
    For that size motor 8 to 12 uf is a common size. The capacitor is usually wired between red and white with black being common or neutral, live going to red or white depending on which way the motor runs. You will need a continuously rated 275 volts AC or higher voltage capacitor.
    Usual disclaimer applies.
  1. Single Phase Motor Wiring
    By grunto in forum METALWORK GENERAL
    Last Post: 18th Sep 2015, 12:26 PM
  2. Single phase induction motor wiring help needed
    By simonl in forum METALWORK GENERAL
    Last Post: 21st Apr 2012, 05:23 PM
  3. Star/Delta motor wiring
    By .RC. in forum METALWORK GENERAL
    Last Post: 3rd Mar 2012, 11:01 PM
  4. Wiring of a single phase motor.
    By krisfarm in forum METALWORK GENERAL
    Last Post: 28th Oct 2010, 08:10 PM
  5. motor wiring diagram
    Last Post: 12th Jul 2010, 07:37 PM
