Results 31 to 43 of 43
Thread: Question for the VFD Guru's
13th Sep 2017, 12:27 PM #31Most Valued Member
Other than costing a little more. None.
Yes at 10 amp
The VSD being only 5hp doesn't matter, you're never going to get that much as currently wired.
12A is about spot on 1/2 your 7.5hp? 23A would only happen at 7.5hp which was never going as it is.
13th Sep 2017, 01:02 PM #32Member: Blue and white apron brigade
Only that it's a good idea to make sure the max current the VFD can supply has been changed from the default max current for a 2.2kW motor otherwise there is nothing protecting the 1.5kW motor.
On my HM-45 it has a 1.1kw motor and I am running a 1.5kw vfd and never had an issue.
13th Sep 2017, 05:36 PM #33
Will let everyone know how it turns out, thanks for all the advice.
Shane
Got the square peg in the round hole, now can't get it out !!
17th Sep 2017, 10:39 AM #34Most Valued Member
Hi Aus,
I think that machine must have come with several voltage options. One of those options was to run on 240V. I think the text refers to circuit if the machine was configured to 240V. In which case the transformers would have a 240V primary.
I think you will need to make some changes to the transformers etc. But for $800 I would not be complaining. You got yourself a good buy but it will need some mods for your particular use.
26th Sep 2017, 08:03 AM #35
$800 HM-52G wired with VFD, no wiring changes to the Motors just removed most of the wiring from the power box and added the VFD, added a separate transformer for the power feed and need to change the coolant pump. Left all the switching in place for the motors and everything works fine.
Ordered 3 Axix DRO from Aliexpress for $320 Aus.Shane
26th Sep 2017, 08:25 AM #36Most Valued Member
Nice!
Is the Hoz spindle wired as well? You're just using a 3 pole switch to select motor?
Did you look in the Hoz spindle motor terminal box? as it's(I assume) a single speed motor you maybe able to change that to run at full power easily(if you ever feel the need).
If you aren't using the buttons on the VSD for controls I'd move/cover it or chances are one day you'll get some swarf in there and let the magic smoke out.
26th Sep 2017, 08:52 AM #37
Yep Horizontal is wired as well, use VFD buttons for forward and reverse, left original switching as VFD wired into main feed for both motor, use original switches to switch between Hoz and Vert. Couldn't mount VFD on Vert head as I would have liked because when used in Hoz mode head is around the back
Shane
26th Sep 2017, 09:45 AM #38Member: Blue and white apron brigade
I agree with Stu - it needs a cover and Not sure I'd like to have to reach over the work area to get at the VFD control.
When you cover it you might want to look at mounting wired remote controls in a small control box that you can mount onto the head and move around like this.
This box is on my WW bandsaw and has a magnet attached to the back so it can be located to where it is best accessible
26th Sep 2017, 11:53 AM #39
The VFD control is a seperate little box that pops out you know? You could then get a longer cable for it and mount it anywhere. You could even mount it with magnets so it can be moved as required. The flat cable connector does stick out the back a bit and should be protected/sealed. These cables can be bought at any electronics store or made up from the parts.
My VFD (lathe) is in a plastic electrical box. The control unit sits on the door of the box and has enough cable so the door can be opened easily to access the inside of the box. I don't use the controls so it is just there as a display. The controls are standard switches on the lathe switch panel plus a multi-turn pot for speed. The advantage of this is it is quite accurate and has a counter which enables you to dial in any speed you want. I just use the frequency readout to set speed.
26th Sep 2017, 07:15 PM #40Most Valued Member
I mounted my pedestal drill's VFD in a case with a clear lid so I can read the frequency and then cross-refer to a table to get RPM as Dean suggested.
26th Sep 2017, 07:43 PM #41Member: Blue and white apron brigade
Chris, What about cooling?
26th Sep 2017, 07:45 PM #42Most Valued Member
It doesn’t seem to be a problem.
Sent from my iPhone using TapatalkChris
26th Sep 2017, 11:34 PM #43
My housing is a little bigger than Chris' and has a digital thermometer with the sensor sitting close to the VFD. It never rises much above ambient. I thought I would do this to start with and deal with the cooling later as deemed necessary. No need. It might be different if a lot of heavy machining was happening.
Question for the welding Guru Grahame
By DJ’s Timber in forum WELDINGReplies: 8Last Post: 11th Feb 2008, 12:19 PM -
question to mod's re PM's
By Zed in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 5Last Post: 12th Sep 2007, 11:34 PM -
IT Guru question
By Soren in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 8Last Post: 17th Jun 2005, 11:07 PM
