Results 16 to 17 of 17
Thread: Is this motor correct
16th Apr 2017, 11:11 AM #16Senior Member
- Oct 2009
- Upwey VIC
- 187
Azz,
If it is the single phase input unit I suspect it will be fine as long as your workshop is not in an overheated Tibetan monastery.
The Danfoss units seem to be very robust in my experience.
Andrew.
16th Apr 2017, 07:08 PM #17Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
hi Andrew.
that a good point. a 2.2kw drive will work fine. you over rate the drives for things like hot days.
For now the danfos is staying on the shelf . the jobs done with the cheap drive .
ive been making lots of swarf.
Is a motor start relay switch needed for a 3ph 2.8kw pump motor?
By Ben Dono in forum METALWORK GENERALReplies: 26Last Post: 14th Aug 2015, 02:38 PM -
Correct way to make this
By Tiger in forum METALWORK GENERALReplies: 8Last Post: 25th Apr 2014, 12:49 AM -
What is correct?
By Wombat2 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 2nd Oct 2012, 10:54 PM -
advice on correct setting of mig
By welder in forum WELDINGReplies: 5Last Post: 29th May 2011, 07:48 PM -
Cylinders - Are They Correct?
By Metal Head in forum METALWORK GENERALReplies: 7Last Post: 19th Jun 2007, 10:06 PM
