Results 1 to 4 of 4
5th Apr 2017, 07:14 PM #1Most Valued Member
- Charlestown NSW
- 1,669
circular glass scales - worth keeping?
Gday .
I salvaged an old, early electronic theodolite from a dumpster death at work. They haven't been used for years and this one had damaged optics.
I basically grabbed it to pull it apart to see what was inside.
I'm not an electronics person so have no idea.
It has 2 circular glass scales with some sort of reader attached.
I have all the electronics but I didn't test anything before disassembly. It was probably still working.
These things are pretty accurate in measuring angles and I was wondering if they would be of use to someone as encoders?
If anyone wants them they can have them if they pay for the postage.
The one on the right is for the horizontal axis and the one on the left for the vertical axis. Horizontal is designed to read complete 360deg.
Not shown in the pics are the rest of the boards.
peter
13th Apr 2017, 10:57 AM #2Diamond Member
- Aug 2006
- 1,105
Hi, could be interested in these, also any other of the electronic parts you may have for the theodolite. I have a damaged theodolite here with bad electronics but the mechanicals are good. Do you recall the model of this theodolite?
14th Apr 2017, 12:18 AM #3
They look like absolute position rotary encoders. With 16 wires going to the photocells, I'd hazard a guess they might be 12 bits. Might even be encoded as direct reading in degrees.
See if you can find a part number or some sort of identification.
14th Apr 2017, 08:59 AM #4Most Valued Member
- Charlestown NSW
- 1,669
Sokkia DT4 is the theodolite. I'll have a look to see if there are any part numbers. I have the complete electronics part. Had to cut a cuople of wires to get it art but they are easily rejoined. However I didn't take note of what ribbon cable went where as I wasn't really thinking about the possibility of potential reuse at that point.
peter
Circular Saw Blade
By cava in forum METALWORK GENERALReplies: 19Last Post: 21st Mar 2017, 06:14 PM -
Compression scales
By SAISAY in forum METALWORK GENERALReplies: 9Last Post: 1st Jan 2015, 10:30 AM -
Worth keeping this shaper?
By yashinskiy in forum METALWORK GENERALReplies: 13Last Post: 21st May 2012, 11:20 AM -
Distance Scales
By Anorak Bob in forum METALWORK GENERALReplies: 27Last Post: 10th Dec 2011, 07:34 PM -
Schaublin Mill Graduated Scales
By Anorak Bob in forum METALWORK GENERALReplies: 0Last Post: 10th Dec 2010, 09:32 PM
