Results 1 to 2 of 2
5th Apr 2017, 06:01 PM #1Golden Member
- Apr 2009
- Kingswood
- 930
Coolant Pump 3-ph to 1-ph with Capacitors
I have 2 off ex-industrial ex-auction 3-ph 415/240 Vac good brand coolant pumps 1/8 hp.
Each tests ok for continuity and insulation and will run on 1-ph 240 Vac once spun by hand.
Can anyone please confirm that it is worth the cost and fuss of adding appropriate capacitors to install them on a machine tool, as compared to scrapping or selling and purchasing new 1-ph units ?
John
5th Apr 2017, 06:51 PM #2Member: Blue and white apron brigade
- 7,182
It depends on what sort of a load the motor is under. Under light load it might be worth it, but if they are working above about 50% of their HP rating they will overheat.
You can get a crude check of the HP by seeing how much current they draw and using say a 60% efficient rating for a small motor.
A back of the envelope calc - someone else please check
The nominal input power @ 1/8 HP and 60% efficiency would be 745/8/.6 = 155 W
On 240V that would make it 650 mA
If it draws more than 350 - 400mA I would be wary of using it.
If you do use it you might want to run it and monitor temps before you set and forget.
Rather than purchasing a new SP motor and go though the headache of fitting it might be easier and cheaper to purchase a small used VFD , then you could control coolant flow through pump speed.
I have a beautiful fully SS closed loop coolant pump I want to set up for a water cooled TIG torch. It has a 1/8 3P motor on it and I will be fitting a VFD to it.
Washing machine pump as a coolant pump
By BobL in forum METALWORK GENERALReplies: 66Last Post: 9th Oct 2015, 09:25 PM -
Coolant pump motor?
By wm460 in forum METALWORK GENERALReplies: 11Last Post: 13th Sep 2015, 06:00 AM -
El cheapo coolant removal pump
By Grahame Collins in forum METALWORK GENERALReplies: 19Last Post: 15th Mar 2012, 01:20 PM -
Macson hacksaw coolant pump
By smokey2 in forum METALWORK GENERALReplies: 1Last Post: 29th Mar 2011, 12:04 AM -
Coolant Pump
By electrosteam in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 5th Nov 2010, 06:25 PM
