Results 1 to 3 of 3
Thread: Y to ∆ conversion problem.
10th Oct 2016, 10:10 PM #1Member: Blue and white apron brigade
I decided to convert a 1HP Y motor to ∆ this arvo.
However the common point is at the other end of the motor and there are no pathways available through the inside of the motor.
The only thing I can think of doing is drilling a hole in the end cap and using conduit to take the ends of the coils at the common point back up the outside of the motor to where the other ends are?.
Anyone have any other ideas?
11th Oct 2016, 02:39 PM #2Senior Member
- Mar 2013
- Mt Pleasant SA
- 126
Sounds like a rational way to do it if there really isn't room for a more conventional job. What an inconsiderate b...... to connect it that way! The star point I mean, not your idea. What will you use..some sort of metalflex conduit? Failing that maybe a suitable size copper tube would allow the bends needed.
11th Oct 2016, 06:52 PM #3Member: Blue and white apron brigade
Ended up going with a gland in the front end cap.
I was looking at metal tubing but in the end I just sheathed the wires from the common point into a single 5mm tough fibreglass sheath, did the same to the other end and brought both sets of wires into a junction box on the side of the motor and from there to the VFD. It's a bit of a kludge but the motor (drives a wood work lathe) or wiring is out of the way up under a bench and so its not going to get knocked about. It will fool someone who doesn't know about motors if the go take a look at it - I might write something inside the junction box.
HM52 CNC Conversion
By RayG in forum METALWORK GENERALReplies: 187Last Post: 9th May 2016, 07:55 PM -
AL-54B CNC Conversion
By aussiejoeblow in forum METALWORK GENERALReplies: 18Last Post: 22nd Jul 2011, 09:38 PM -
oxy lpg conversion
By the fabricator in forum WELDINGReplies: 7Last Post: 19th Sep 2010, 07:55 AM -
CNC conversion
By sonic_racing in forum METALWORK GENERALReplies: 7Last Post: 18th Jan 2009, 03:11 PM
