Results 1 to 7 of 7
25th Sep 2016, 08:29 PM #1Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
Old Bench Drill Running in Reverse
Hi Guys
i picked up a rather old bench drill today from Gumtree it seemed to run good at the sellers house but i just hooked it up to use it and noticed its running in reverse and there is no direction switch
am i able to reverse the polarity after the ON/OFF switch and before the motor? if i am able to will this have any effect on the capacitor?
i don't want to burn anything out nor do i want to invest in a whole range of reverse drill bits
25th Sep 2016, 09:40 PM #2Philomath in training
Is it single phase or 3 phase?
if 3 phase, all you have to do is swap 2 of the three wires over.
If single phase it will depend on the motor.
25th Sep 2016, 10:41 PM #3Most Valued Member
- Aug 2009
- 1,844
It's single phase, after watching a video on youtube i cut one of the capacitor wires and just hand turned the drill to start it that should work for now
a drill press is a heck of a lot easier to drill out a broken bolt than holding a hand drill
25th Sep 2016, 11:03 PM #4Most Valued Member
- 4,890
Depends where or what the bolts in.
25th Sep 2016, 11:52 PM #5Most Valued Member
- Aug 2009
- 1,844
This is what i'm trying to do pipeclay, i need to drill out those two rounded JIS screws and the tiny 2-2.5mm snapped screw
This is a jetski carburetor i was overhauling untill i stripped the screws, basically the jetski was sunk and no care was given after it was resurfaced so the salt water sat inside the carburetor chambers untill it eventually evaporated
I was given advice to drill the screw heads off i have done so but the inner piece that is screwed down is still stuck so tomorrow i will attempt to drill out the remaining bolts and possibly helicoil it if there is enough meat at the base i will have to check on the second carburetor
25th Sep 2016, 11:54 PM #6Most Valued Member
- Aug 2009
- 1,844
Forgot the pic
29th Sep 2016, 10:02 PM #7Most Valued Member
- 4,258
Sounds like the start capacitor is cactus and or start windings
Richardson E39 Bench Drill Press Restoration
By Blu_Rock in forum METALWORK GENERALReplies: 11Last Post: 28th Sep 2022, 10:17 AM -
Hercus 260 Running in Reverse
By turbodude in forum THE HERCUS AREAReplies: 12Last Post: 1st Aug 2013, 09:28 AM -
Waldown Hispeed bench drill
By RJT in forum METALWORK GENERALReplies: 6Last Post: 29th Sep 2012, 10:06 AM -
Old line shaft bench drill
By bollie7 in forum METALWORK GENERALReplies: 40Last Post: 13th Apr 2011, 10:04 PM -
Mini Mill/Drill with forward/reverse
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 27th Feb 2009, 11:31 PM
