Results 1 to 5 of 5
Thread: Replacement lathe motor
2nd Sep 2016, 11:23 PM #1Novice
- Jul 2008
- Sydney Australia
- 76
- 22
Hi,
At our Men's Shed we have a Yangzhou lathe with a 1.5 kW single phase 4 pole motor which has died. It has a 100L frame which is odd in that rating, most 1.5 kW motors are 90L, a bit smaller. We are restricted to a 10A supply for it, so 1.5 kW is about the maximum.
We think a 1.5 kW replacement motor in a 90L frame with a shaft sleeve and a 10 mm adapter plate for the foot mounting might be the way to go. Has anyone here conquered a problem like this?
Geoff
3rd Sep 2016, 11:41 PM #2Member: Blue and white apron brigade
- 7,183
if there is enough room its pretty easy to make an adapter plate to match the two frames.
I di this on my compressor just by using two lengths of 50 mm SHS with the holes for each offset to match on either side.
On a drill press at the mens shed I used an 8mm thick steel plate with weld 10 mm threaded studs on each side, one set of studs went onto the DP frame and the other for the motor.
4th Sep 2016, 09:34 AM #3Philomath in training
- 6,541
I did once...
Jacking the motor up is not a real issue. Adapting the shaft to get the existing pulley to match and run true is more difficult, especially if your current motor was custom and had a shaft longer than standard and the replacement is standard off the shelf. When going down in size the length is often reduced too. I'd be tempted to (permanently) sleeve/ bush the pulley myself if going that way.
In Adelaide we have a company called Royce Cross who claim to have the best electrical motor service in Australia (1300 553 229 - deliver nationally) if you have not contacted them already it may be worth asking if a change over motor can be found.
6th Sep 2016, 12:06 AM #4Novice
- Mar 2016
- Sutherland Shire, Sydney
- 24
Hi Geoff, if you are anywhere near The Shire, Suann Electrical are electric motor experts (he must have 500 sitting on the shelves there), they are in Taren Point, Cawarra Rd I think
6th Sep 2016, 07:10 PM #5Novice
- Jul 2008
- Sydney Australia
- 76
- 22
Thanks everyone,
I am contacting these companies.
Another interesting option for lathe/mill motor replacement
By PDW in forum METALWORK GENERALReplies: 6Last Post: 20th Jan 2016, 09:30 AM -
T and C Grinder Workhead - Drive Motor Replacement.
By Anorak Bob in forum METALWORK GENERALReplies: 11Last Post: 18th Jun 2014, 07:46 AM -
EMCO UNIMAT #3 replacement motor
By vk4 in forum METALWORK GENERALReplies: 10Last Post: 16th Aug 2013, 08:08 PM -
drill motor replacement
By jack620 in forum METALWORK GENERALReplies: 47Last Post: 21st May 2011, 11:42 PM -
Motor replacement
By BobL in forum THE HERCUS AREAReplies: 16Last Post: 5th Jan 2010, 09:42 AM
