Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    May 2009
    Booval Ipswich
    85
    13
    Default Single to Three phase converter
    Hello to all, and hopefully one of you Lads can provide advice... I have a 3 phase Milling machine and want to run it off a single phase supply. It has a 1.5 HP motor on it.
    I need to know the best way to jump.
    Kind Regards, John
    Oct 2006
    Armidale NSW
    52
    915
    If only one motor, probably a VFD would be "easiest". Other options are a static or rotary phase converter, or even a single phase motor swap.
    Cheers.
    Vernon.
    Jun 2007
    Vic
    48
    544
    Hi John,
    I am using this unit and it seems ok. The extra knob on the control pad for frequency control is nice. Search for "VFD" in the forum, there are a few threads
    1500W 2HP 240V 7A Single Three Phase Variable Frequency Drive Inverter VFD | eBay
    Nov 2005
    adelaide
    597
    If you go the vfd way make sure you can configure the motor to delta depending on which motor some just need to have the jumpers changed ive just converted a Tom Senior mill which didnt have jumpers but with a bit of careful study it wasnt too hard to find the star point junction and change it.If your not too sure i suggest a motor rewinder or sparky should be consulted
    John
    Jan 2011
    Far West Wimmera
    63
    4,049
    It would be useful if you could post pictures of the motor data plate and the motor connector block. There may be a diagram of the motor connections under the cover of the motor connection block as well.
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    I agree with Dean: Show us the motor and we'll help you avoid some traps.
    Also, the $150 VFD jackaroo pointed out to you is the better choice over the lower cost ones currently on eBay. It is a Huanyang and lots of people here have them and have gathered lots of experience with them (including me). The lower cost current crop isaninferior product with minimal settings only. I got 'trapped' by the price andthe very similar look of them.They are significantly different to the Huanyangs.
    You other alternative is to contact Chris Parks by PM (a member on this forum) who can source a Powtron VFD which is a bit better still.
    Cheers, Joe
    May 2009
    Booval Ipswich
    85
    13
    Hi Lads, Thanks for the replies... I have been a bit off colour lately and have not had a chance to reply. I have taken a few pictures and will post them when I get over this minor OP this coming Monday. I seem to take a lot longer to do anything these days, bugger to be getting Old.
    John
    May 2011
    Murray Bridge S Aust.
    5,956
    Get well soon, John
    Dec 2015
    202
    //metalworkforums.com/f303/t198...b-600-a/page-5
    posts 4 thought to 10 is me rambling through the same problem!
    good luck
    May 2009
    Booval Ipswich
    85
    13
    Default How the Heck do You/I include a photo??.
    Having trouble getting around sending a couple of pictures... I'll try with this message...NO Luck
    Jan 2011
    Far West Wimmera
    63
    4,049
    May 2009
    Booval Ipswich
    85
    13
    Default Success at last, thanks Dean
    Well I think I have attached two photo's containing the needed info, and thanks to Dean for pointing me in the right direction. I hope that it will provide enough to enable a solution to my problem. And, I only need the
    device for one motor. no info inside the cover.
    I do have a three phase motor and controller on a VICMARC VL-300 wood lathe but it was all setup when I bought it many years ago. I did make a four foot extension to enable me to turn stuff up to
    eight feet long. My brother wanted me to turn the posts for a 4 poster bed he wanted, out of cedar and that was the reason for the extension. The lathe is able to run from about 30 to 3000 revolutions per minute at
    the turn of the Pot...
    John
    Oct 2006
    Armidale NSW
    52
    915
    If I'm reading that right, it's a 2 speed motor ... not 100% sure, but I don't think you can run them off a VFD (or at the very least you will lose the dual speed facility)
    Cheers.
    Vernon.
    7,188
    That is indeed a 2 speed (Dahlander, ∆/2Y) motor.
    It is wired for 415V only.
    On either speed (even the ∆ config) it will only run at half power on 240V 3P.
    It can be rewired internally only for the 2Y side, converting it to a 2∆ which will develop full power at 240V 3P.
    I don't think motor rewinders would approve of this and it would be better and not much more expensive to buy a new dedicated 240V 3P motor.
  15. #15
    Jan 2011
    Far West Wimmera
    63
    4,049
    Does the mill have 2 speed settings?
    It seems the motor is Delta/YY. Normally you would find which connections were the Delta ones. This would be the black wires labelled with either 1UVW or 2UVW. These delta connections would be connected to the output of the VFD.
    Delta will give 1480rpm and YY will give 2850rpm if I am reading that plate correctly.
  1. DONE: Single to three phase converter
    By Allan&glen in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 13th Oct 2012, 05:37 PM
  2. Single to Three phase converter
    By shedhappens in forum METALWORK GENERAL
    Last Post: 10th Sep 2012, 11:53 PM
  3. 3 phase converter figures.
    By aussiejoeblow in forum METALWORK GENERAL
    Last Post: 21st Aug 2012, 09:22 PM
  4. Yet another phase converter question
    By Gerbilsquasher in forum METALWORK GENERAL
    Last Post: 27th Apr 2010, 12:02 PM
  5. More phase converter questions
    By Fossil in forum METALWORK GENERAL
    Last Post: 16th Jun 2006, 07:23 PM
