Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Old motor & VFD
  1. #31
    Aug 2004
    Perth Western Australia
    65
    203
    Default Primary Connections
    I'm sorry I took so long to take these. I had a busy couple of days.
    I hope these will help you work out what is what.
    The angles I could shoot were very limited.
    Thank you again Mark
    I've become a tool of my tools.
  2. #32
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by DSEL74 View Post
    I had a heart attack
    Just caught up with this post...
    Thats not good Dale!
    hope you are well on your way to good health.
  3. #33
    Dec 2007
    1,628
    Thanks mate, I'm doing ok started rehab on Wednesday.
  4. #34
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Hi Dale,
    hope your rehab is going well!
    Finally got a chance to work out your transformer and the connections required to change it to a 240V to 415V auto transformer:
    This circuit will increase the output voltage as required. Please be VERY aware that this will give you 415V to GROUND! So be suitably cautious dealing with the 415V connection at "T"! E.g. use cable with insulation suitable for 415V and protect it mechanically as well.
    This is still single phase. So you will need to use a VFD that can actually run on SINGLE PHASE 415V, as mentioned by Ray et al. i.e. a 415V VFD which does not throw an error and switches off for a "missing phase".
    I happen to know that some Siemens VFDs will allow single phase running at half the rated capacity. I'm sure other brands will too. Some may need to be fooled by connecting two of their 3 inputs together.... other will not start at all.
    Good luck - both with your machine and your recovery.
    Cheers, Joe
  1. Replies: 26
    Last Post: 14th Aug 2015, 02:38 PM
  2. Replies: 26
    Last Post: 1st May 2015, 04:42 PM
  3. Replies: 7
    Last Post: 10th Mar 2014, 07:26 PM
  4. new motor
    Last Post: 29th May 2012, 06:39 PM
