Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Sep 2006
    Australind , WA
    58
    1,277
    Z axis is all done.
    I added a second magnet to see if that increased the magnetic flux enough to give me earlier activation and it worked well.
    When the new , thicker magnets arrive I'll swap them out.
    I thought the 3mm thick ones would be heaps, but apparently not...lol The new ones are 6 mm thick. Other dimensions the same (20 x 10mm.)
    I started on the X axis today as well. Worked out how the mount the switches and fabricated 2 mounts. At least the wiring will be run alot easier for the last 2.
  2. #17
    6,440
    Thumbs up A112 Hall switch.
    Hi Steve,
    The devices that I have are marked A112 and E964 both are in TO92 packages. The only data that I could find was these
    A112x-Datasheet.pdf
    Infineon-TLV4964-5TAB_Hall_Switch-DS-v01_00-DS-v01_00-EN.pdf
    I did find another applications note from Infineon which I can attach if you want it.
    HTH.
  3. #18
    Sep 2006
    Australind , WA
    58
    1,277
    Hi Baron,
    Thanks for that. I think these will be ok. Ive come too far to change now anyway...lol.
    I'm getting about 3 mm clearance so that will work out well.
    I didn't realise there were so many Hall Effect IC's around.
  4. #19
    6,440
    Thumbs up Data Sheets.
    Hi Steve,
    I've been having a look at some info for Mach 4. I found it interesting and based on some things in there I went and found a couple of data sheets that you might find of interest.
    It appears that Mach requires a digital signal, that is, a rapid transition from a 0 to a 1 and vice versa. The Hall devices that you are using are a linear output, which means that the change in output level will be quite slow. In fact only as fast as the mechanism can move the magnet over the Hall sensor.
    Whilst you said that it seems to work just fine, there is the danger that the input to the Mach ends up in an indeterminate state which could cause other issues.
    Unfortunately the Hall devices that I have of this type are tiny surface mount Sot23 size and will not fit into your holders otherwise I would send you some.
    Anyway I've attached the two data sheets for the ones refered to in the Mach 4 handbook.
    OH44E_Hall_Switch.pdf
    Hall A3144.pdf
    PS. Sorry for the delay in responding, things keep getting in the way.
  5. #20
    Sep 2006
    Australind , WA
    58
    1,277
    Last axis all done. Just have to tidy up the wiring...woo hoo.
    The thicker magnets have't arrived yet, but that will on'y be a 5 minute job to swap them out, when they do.
    It was a long job, but will stop me damaging anything if make a mistake.
  1. Effect of electric brakes on the wrong side
    By beefy in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 1st Sep 2014, 08:22 PM
  2. A Harold Hall dividing head
    By fxst in forum METALWORK GENERAL
    Last Post: 18th Jun 2012, 11:19 AM
  3. Harold Hall
    By rfurzer in forum METALWORK GENERAL
    Last Post: 3rd Sep 2011, 10:59 AM
  4. CNC Mill Limit Switches
    By electrosteam in forum METALWORK GENERAL
    Last Post: 10th Sep 2010, 07:31 PM
