Results 1 to 4 of 4
    May 2010
    135
    Default paving advice sought - WA
    hi,
    nearly every paving guide talks about putting compacted roadbase under the pavers as a sub base, then about 30mm of sand as bedding... but some don't specify the gravel/ roadbase layer - they simply opt for compacted subsoil, and then a bedding layer.
    So here I am digging out the crappy grey sand which passes for soil in my part of WA and I've come across the compacted yellow brickies sand I paid to have put in as part of the pad prep. This is 300mm thick, and compacted with one of those BIG industrial compactors (weighs about 1T) - the sand would pass for weak limestone, or weak concrete.
    it seems silly to dig this out and replace it with roadbase and then recompact it... especially since my compactor is only one of those smaller domestic types which weigh around 50-60 kg.
    does anyone know what i should be doing here...
    where the compacted yellow sand has not been done (the last meter of the proposed paving) I've dug down 300mm and will either fill with roadbase, or compact brickies sand in 50mm lifts up to the level of the bedding sand.
    The bedding sand will be the proper 30mm thick screeded layer as per every guide i've read.
    Thanks,
    Des
    Aug 2000
    34
    Crappy grey sand in the Pilbara, I thought the grey stuff was only down in Perth and it was all red up there ?
    I guess the biggest question is what is going on top of the paving, is it your driveway and is it going to have vehicles going up and down it or sitting on it all the time? If the yellow sand is as consolidated as you say then I think you will probably get away with it.
    May 2010
    135
    It is in perth... Need to update profile.
    The paved area will occasionally have vehicles drive on it.
    Sep 2007
    Country West Oz
    77
    169
    Years ago when I lived in Perth, I did paving on compacted yellow sand as you describe, occasional vehicle traffic, but mostly foot traffic, did not have any problem with it at all.
    Bradford
  1. advice sought - drilling stainless steel mixing bowl
    By desbromilow in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 29th Apr 2018, 08:55 PM
  2. Advice Sought Regarding Rust Removal From Cast Iron Table
    By Becephalus in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACK
    Last Post: 3rd May 2014, 11:46 AM
  3. vice repair advice sought - cast iron
    By desbromilow in forum METALWORK GENERAL
    Last Post: 20th Sep 2013, 01:35 PM
  4. Lamps, Lumens and LEDs - Advice Sought.
    Last Post: 22nd Jul 2013, 12:10 AM
  5. Advice sought on brushing aluminum
    By Tenson in forum METALWORK GENERAL
    Last Post: 28th Apr 2008, 01:23 PM
