Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 50
  1. #31
    Jun 2007
    sydney ( st marys )
    64
    4,887
    How much load do you have on your tapered lock nuts ?
    Is it possible to also secure the job with a bolt through the leg just in case there is some type of vibration that may cause your locking nuts to come loose.
  2. #32
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Looks good so far (and believe it or not, along the lines of my original (vague) thoughts).
    Spider for the free end?
  3. #33
    May 2011
    Murray Bridge S Aust.
    5,942
    Quote Originally Posted by Steamwhisperer View Post
    Thanks Kryn
    the base is 25mm thick plate and the bolts are 9/16"UNF so I'm hoping...
    Phil
    Hi Phil, the reason I mentioned about extra bolts was that I saw the chalk line and thought it was going to be cut there.
    I need to look/read further before putting my foot in my mouth!!!!!
    Interesting way of dong this, THANKS.
  4. #34
    Sep 2011
    Ballarat
    65
    3,103
    Hi Peter
    there is a good load but they are more for location and a bit of workholding. I definitely need something to secure it with more rigidity. I like your idea of a bolt through the leg as I was going to run a strap from the flange to the faceplate.
    Hi Michael
    Yeah, maybe not so vague. The beauty of this jig is that it will work on a milling table (should I ever get one).
    A spider is the most secure way though with the gap I'm not sure the steady will still be able to sit on the ways. If it does, I'll have to give it a crack.
  5. #35
    Sep 2011
    Ballarat
    65
    3,103
    Hi all
    I returned the faceplate to the lathe (removing the insert for the gap was a lot easier this time) and made the necessary adjustments to get the governor to run about as true as it's going to.
    Seems there was ample space for the fixed steady so I made a spider up for the support that was needed during machining.
    I also did a short video of the governor turning in the lathe in case anyone would like to see it. The counterbalancing worked incredibly well I just wasn't game to run it too fast.
    https://www.youtube.com/watch?v=26y8ldW53qs
    Phil
  6. #36
    Oct 2011
    59
    6,540
    Brilliant Phil. I think the spider is a good idea just because you don't want things to move halfway through boring, and being an interupted cut, Murphy is watching carefully.
  7. #37
    Sep 2011
    Ballarat
    65
    3,103
    Thanks Michael
    With a bit of luck the large mass in the spider may soak up a bit of the vibrations should there be any chatter.
    I'm sure Murphy actually resides near my house.
    Phil
  8. #38
    Oct 2011
    59
    6,540
    One trick I haven't tried but I'm told works (by someone who has talked to someone who has done it...) is sticking a lump of bluetack on the rotating part. This guy was talking about milling cutters but I would have thought it might work on a lathe. The rubbery nature is meant to damp down the tendancy for the metal to ring/ vibrate. Your part is a bit large probably for that trick but I wonder if you used say a worm drive hose clamp to hold some soft rubbery material in contact whether you would get the same effect?
  9. #39
    Sep 2011
    Ballarat
    65
    3,103
    Yep anything to change the harmonics. Years ago on a particular job I put some big elastic bands around a drum roller I was machining and it shut it up beautifully.
    Phil
  10. #40
    Adelaide
    68
    1,373
    I use the blue-tack method when machining aluminium & magnesium kart rims, it's very effective in damping the ringing we get otherwise.
  11. #41
    Sep 2011
    Ballarat
    65
    3,103
    Wow, over 8 months since my last post.
    I managed to machine the outrigger arm successfully which after reaming to final size, I finally had a decent bore to work with.
    Next bit was the bush for the outrigger arm.
    I will point out (and you know I'm going to always bang on about this) that there was no Loctite used but the 'Limits Fits and Tolerances chart got a decent work out. I figure if it can hold together for over a hundred years without Loctite, then it will again.
    Phil
    20190628_143817 copy.jpg 20190628_121349 copy.jpg 20190701_140206 copy.jpg 20190701_084824 copy.jpg 20190701_092727 copy.jpg 20190701_131909 copy.jpg 20190701_132058 copy.jpg 20190701_142043 copy.jpg 20190701_142048 copy.jpg 20190701_132705 copy.jpg
  12. #42
    Oct 2011
    59
    6,540
    Well done Phil. I re-read the whole thread (twice) to get my head back around what you were doing, but it looks like you have nailed it.
    Does this mean that Ballarat is now the world-wide centre for Pickering rebores?
  13. #43
    Sep 2011
    Ballarat
    65
    3,103
    Thanks Michael
    and you would be correct.
    And when I figure out the geometry for cutting bevel gears on the Douglas, I'll be able to do the lot.
    Phil
  14. #44
    Jun 2007
    Ipswich QLD
    68
    1,996
    Another great journey and tutorial by a true master. Thanks Phil.
  15. #45
    Sep 2011
    Ballarat
    65
    3,103
  1. Machining job needed - any takers?
    By Clinton1 in forum METALWORK GENERAL
    Last Post: 3rd Jun 2013, 08:41 PM
  2. Urgent machining job needed in perth.
    By lather in forum METALWORK GENERAL
    Last Post: 22nd Feb 2012, 07:08 PM
  3. aluminium machining advice needed
    By horse in forum METALWORK GENERAL
    Last Post: 12th Jan 2010, 02:10 PM
  4. Hercus 260ATM Install & Initial Setup Details Needed
    By jackafrica in forum THE HERCUS AREA
    Last Post: 28th Sep 2009, 07:34 PM
  5. Machining Needed in Sydney - low volume/prototype
    By missionaryman in forum METALWORK GENERAL
    Last Post: 29th Jan 2006, 08:01 PM
