Results 46 to 60 of 75
Thread: Chainsaws and Poona Trees.
14th Jun 2017, 12:44 PM #46It is easy in my area because there are chainsaws everywhere and there is a bloke about 90km away who specialises in lawnmowers and chainsaws. Walk into his workshop and there is probably 100 saws around.
When I run out of bar oil, which I often do, then I make a mix of engine oil and auto-transmission fluid.
14th Jun 2017, 03:05 PM #47Senior Member
- Feb 2013
- Bunya Mountains, Australia
- 69
- 182
It's just that they were the only two chemicals I had to hand
I added the transmission fluid just to make it less viscous in case the engine oil was not suited to the oil galleys of the saw. Better to have it flooding out than not at all I thought at the time. It has worked, for whatever reason, as the bar has not worn ... or it could be that Dolmar make a very good bar, despite my mistreatment.
The disadvantage is that you have to clean the dust-extractor volute quiet often. The sawdust gets damp with oil and clogs.
I oil the chain with transmission fluid before I start the saw. It seems to lubricate and act as solvent. That is, you start the saw, and before the bar oil has begun to reach the chain the auto fluid flies off everywhere and takes all the gunk sawdust etc caught on the chain with it.
By the time the bar oil replaces the auto fluid you have a nice clean chain to set off with.
ummmmm ... I wouldn't necessarily take my advice, it works for me. But I know nothing about saws, just experimented with my own.
Greg
14th Jun 2017, 03:23 PM #48Senior Member
- Feb 2013
- 69
- 182
You're probably right about me babying it, but it's the only one I have and I need it.
Makita recommend, in the manual, that you have the chain machined sharpened after every half-dozen hand sharpens. That's because with a hand file you tend to round edges over time.
I have never had a chain sharpened by machine. When I was first teaching myself I was meticulous about angles, heights and length of tooth. All this I got from the book. I usually full-on sharpen in the workshop and only hone-sharpen when cutting in the forest.
It only takes a few minutes to hone a chain once you are familiar and confident with sharpening. I usually cut down a black-wattle (I hate black wattles. Grass pretending to be a tree) and jam the saw in the forks.
The absolute best thing about field sharpening is that you immediately feel, and hear, the effects of your sharpening. You can tell you've done it right or wrong straightway. This instant feedback is the best teacher, tho it can be frustrating too.
Anyway, your confidence builds and eventually you can sharpen the chain on any angle of support standing on any slope. But it's an apprenticeship and takes a while before you are good enough and familiar enough to perceive results.
It works for me, takes only a few minutes, gives me confidence and cost nothing ... hehee
14th Jun 2017, 03:59 PM #49You're probably right about me babying it, but it's the only one I have and I need it.
I have had a saw sharpened professionally once. I think he did it at 35deg which is common for wood falling. It took ages to get it back to 30deg.
14th Jun 2017, 05:32 PM #50Senior Member
- Feb 2013
- 69
- 182
I only have a guide template that locks to the file. Also the new chain has 30 deg line engraved on each tooth.
Because our arms are cantilever, as me move our arm forward it changes the height of our hand as the arm extends. We counter balance this with our brain in order for our hand to remain steady. Mistakes creep in and become amplified over time. When I was a little baby apprentice we had to file with 'blue'. That's where you learn how unsteady your hand is .... heheee
My biggest problem here, by far, is Lantana. Black wattle is a small weed like tree that springs up in any cacant space at the expense of native grasses. The Bunyas are an isloated Jurassic forest and have some weird grasses, plants, and especially trees. I use Grazon on both lantana and black wattle in my immediate vicinity. Grazon is 80 a litre if you poor. And around 600 if you can afford 20 litres at a time.
It kills (absolutely dead) canes like lantana, root-shooters like black wattle. I won't hurt trees unless you deliberately cover them in it and the native grasses seem to approve of it with a smile. The hazard sheet is mostly caution thru skin irritant. But it's very expensive.
Honing is like when I sharpen my chefs knife on the diamond stone. My knife-draw across the stone become lighter and lighter. I sharpen my knife and my little axe till they shave hair on arm or leg. When they do that, then I hone them.
Greg
14th Jun 2017, 08:02 PM #51Black wattle is a small weed like tree that springs up in any cacant space at the expense of native grasses.
14th Jun 2017, 09:29 PM #52Pink 10EE owner
- 6,218
There are a few species called generic "black wattle". This one is probably the one referred to https://en.wikipedia.org/wiki/Acacia_leiocalyx
It is quite common in narrow leaf iron bark country. The wattles up here are extremely good at suckering from roots, they are hard to kill with Tordon as you kill the upper main plant and a million come to the funeral and decide to stay. In fact in continents like Africa the wattle is a pest plant.
We have a wattle here called corkwood wattle, that is covered with prickles. Such is the diversity of the Acacia familyGold, the colour of choice for the discerning person.
14th Jun 2017, 11:40 PM #53
It certainly is a diverse family. Lots of acacia's outside their normal distribution are pest species. We had coastal wattle growing beside some of the roads near here. Nice bright green foliage compared to many and yellow flowers. Natural to the coast 140 odd km south, but a pest around here. Common names vary a lot in different areas. I go by the names in the books I have, one of which is Trees and Shrubs of South Eastern Australia which is regarded as the Bible for tree identification in this area anyway. We have been on a number of field trips with specialists in plant identification. We wanted to get a better idea about planting trees on the property. This book does not cover Qld tho.
15th Jun 2017, 01:07 AM #54
I have been using a chain saw for more than 30 years cutting firewood for home. I use a Dremel type electric grinder held by hand to sharpen all My saw chains. I never have Them commercially sharpened. I use the biggest diameter stone that will fit in the gullet of the tooth. A battery powered Dremel would make things go faster in the bush. Don't worry excessively about the angles just try to keep them the same.
15th Jun 2017, 10:47 AM #55Senior Member
- Feb 2013
- 69
- 182
Thanx for that. A battery dremel is a great idea for honing the teeth in the bush.
I'm starting to think there are as many ways to sharpen a chainsaw as there are chainsaws. Heheee
Greg
15th Jun 2017, 11:26 AM #56Senior Member
- Feb 2013
- 69
- 182
15th Jun 2017, 11:44 AM #57
Thanks for the pictures. I am not used to seeing seed pods like that on a wattle. This is one of the forms of acacia that does not have leaves on it. The only leaf form that acacia's have is the feathered type. Don't worry I am only showing off my knowledge. I have to do something with it.
The leaf like structure in the picture is a "Phyllode" which is "a winged leaf stalk which functions as a leaf." (Google) Ok I am finished now.
15th Jun 2017, 12:10 PM #58Senior Member
- Feb 2013
- 69
- 182
I'm sorry. I tend to use terms for my own meaning. My methods, and methodology, are probably sacrilege and heresy to anyone who really knows what they're doing.
I'm reluctant to describe my method of sharpening because it will cause outrage amongst the true-sharpeners .. hee
I sharpen my chef's knife, my axe, my chainsaw, my bush-knife using the exact same method for all. There are three steps,
Sharpening, Honing, and Steeling. Each process is different and does a different job. I will write a post on how I sharpen (but I'm sure I will cop flak ..hehee)
Regarding firewood woodcutting:
I split my billets into three different categories, Tinder, Splits, and Bricks.
I use a few 100grams of Tinder to light the fire, then I build a coal-bed using between 6-8 Splits, and from that point I only place Bricks in the fire. I seat the bricks in the coals.
A Brick has a very low surface-area to mass ratio. Tinder has an extremely high surface-area to mass ratio. The surface area of the firewood, not the mass, is the only part of the firewood that can contact Oxygen. Without Oxygen, wood cannot burn no matter how hot it is. (And in this simple fact lies the secret to the Indian Fire-Walking trick, true)
So Tinder burns instantly (In contact with more Oxygen) and Bricks burn all night (very little contact with Oxygen. So, for me, the control of my fire is all about how much Oxygen I let in and how much surface area is available. You may have noticed in your fireplace that once you have a large coal bed you can place a split or a brick in and it doesn't burn. That's because the coals are hotter and demand all the available oxygen. So the brick sits on the red hot coals but doesn't burn. The brick will only burn as the coal bed decreases, and as it burns it creates new coals ... so a brick can keep your whole house warm all night, no problem.
I cut the tinder with my axe which is razor-sharp. The Splits and Bricks I cut with a block-Splitter ... it never gets sharpened. A Brick is a 200mm diameter billet (usually) with the four cheeks taken off with the block-splitter. A Brick is about 150mm across and 300-400mm long. I cut the quantity of all three types in ratio to their use. Altho guests blow this to buggery. A recent guest went thru 10kg of Tinder and a whole box of firelighters (24) in a two night stay. I could have lit 24 fires with that quantity.
Greg
Ps: I will write a post on how I sharpen ... you can use a laugh ... Heheee
15th Jun 2017, 12:20 PM #59Senior Member
- Feb 2013
- 69
- 182
When I said 'root-shooting' I didn't mean that if you cut it, it shoots again from the roots. I suspect that black wattle spreads out it's roots and new trees grow from the roots. So that a clump of black wattle (20-30 trees) are all connected to the same root system, they share it ... and this is their secret, how they spread so quickly.
Up here they're considered an interim canopy plant, along with many others. That is, a tree falls leaving a gap in the canopy, these plants quickly fill the gap ... but they're only temporary occupants because underneath them the red cedars, the hoops, the Bunyas are all shooting and will eventually dominate. The interim plants provide cover and protection for the true-trees (cedars, hoops, etc) while they're saplings.
(I think )
Greg
15th Jun 2017, 12:45 PM #60I'm reluctant to describe my method of sharpening because it will cause outrage amongst the true-sharpeners .. hee
