Results 1 to 5 of 5
    Jul 2003
    53
    67
    Default Bench Grinder Linishing Attachments
    Hi All, the more metal working I do the more I can see the need for a small sander/linisher.
    I have an unused Abbot and Ashby 8 inch grinder, what about peoples thoughts on the performance of the Linishing attachments available?
    ie Linishing Attachments | For Sale Sydney Brisbane Melbourne Perth | Buy Workshop Equipment & Machinery online at machineryhouse.com.au.
    It looks like there are a number of people manufacturing them, which brand/size is best, or are they all the same? Any feedback would be appreciated.
    If anyone has one they'd like to part with let me know
    JJZ
    7,188
    I have an A&A 8" grinder with a 50 x 915 mm multitool attachment and it is one of the most used things in my shed
    The limited power of the grinder means this is about as large a belt as this grinder can drive.
    If you want to be ab;e to use a larger belt I might be better to buy a dedicated linisher.
    e.g. the 100 x 1220 mm attachment LA-484B costs $495, but a basic 2HP linisher with a 100 x 1220 mm belt costs $539
    Bear in mind that both the multitool and cheap linishers are not precision grinding machines.
    If you need precision you'll need to be spending ~3x more than this.
    May 2011
    Murray Bridge S Aust.
    5,958
    Hi Joez, I have the same set up as BobL, and find it acceptable for most of the jobs I need to do on it, including sharpening larger drill bits. I believe that later ones have a plate on the side, that allows bolting on of different attachments. I have the Multitool brand, don't know if it makes any difference though, as I've not used any other brands, total of 3 over the years. Not had any problems with them, just sold them with the businesses. A&A are probably the best around for the price.
    Feb 2015
    Oz
    73
    459
    I currently have the blue belt grinder with a 6" wide belt, it does double service for both metal and wood and is handlywith such a wide belt but for metal the speed is way too slow. If I had my druthers I'd get the Hafco BS-48 which, when considering the price of the bench grinder attachments is fairly good value.
    Jan 2004
    Mackay North Qld
    6,446
    The newer MultiTool attachment to grinder type linishers don't have a good name.The ones I have looked at ( in the shop and attached to bench grinder for demo purposes) have exceptionally bad run out on the drive wheel.Makes em impossible to track correctly.
    The spindle bores were not concentric the the drive surfaces. If you buy personally inspect the one you want to purchase .Don't buy an inline one as H &F won,t cover the postage/shipping back fora faulty replacement.
    Better off try to buy,beg or steal and really old one. When they were made here they were top notch.
    Its possible to build a decent linisher if you are a bit handy. Theres lots of info on the net.
  1. 5" grinder attachments
    Last Post: 30th Mar 2016, 04:19 PM
  2. Dead Bench grinder?
    By jimmyratsbreath in forum METALWORK GENERAL
    Last Post: 29th Oct 2011, 12:59 AM
  3. bench top for a bench grinder
    By wodstok in forum METALWORK GENERAL
    Last Post: 24th Jan 2011, 03:04 PM
  4. 8'' bench grinder issue
    By mistercartoon in forum METALWORK GENERAL
    Last Post: 10th Aug 2010, 04:19 PM
  5. Which 200 mm bench grinder should I buy ?
    By Retromilling in forum METALWORK GENERAL
    Last Post: 16th Oct 2008, 11:31 AM
