Results 1 to 4 of 4
Thread: Bronze plate
27th Dec 2018, 10:14 AM #1Most Valued Member
- Australia east coast
- 2,713
Bronze plate
Need 2 pieces of bronze plate 175 x 175 x 3mm thick - nominal.
I am missing 2 port hole trim rings that have a 165mm OD finished diameter and seeing as they are apparently impossible to buy I'm prepared to machine them.
If anyone is set up to cast them that's acceptable too. I've a pottery kiln but don't want to bother as I haven't done it to date.
Also after a slug of bronze 100mm OD x 20mm thick, also nominal.
And yeah I mean bronze, not brass - these will be exposed to salt water, brass ends up a weak spongy copper matrix as the zinc disappears.
PDW
27th Dec 2018, 06:06 PM #2Philomath in training
- 6,542
Any particular grade? My local supplier (Surman metals) has several to chose from -
https://www.surmanmetals.com/
They sell by the kg, so should be able to manage something for you.
29th Dec 2018, 09:48 AM #3Diamond Member
- Mar 2014
- South of Adelaide
- 1,225
+1 for surman metals. They will also cast material if they don't have a suitable stock size.
31st Dec 2018, 08:27 AM #4Most Valued Member
- 2,713
Probably PB1 from their list. I have found another source but they're being really sloooow getting back to me. Though at this time of year it's not surprising.
Back in Hobart now, where the temperature is a more civilised number. Debugging boat systems and making the fiddly bits (pin rails, belaying pins, battens) resumes. I have all that lovely *space* now.
PDW
Bronze source
By Mike4 in forum GENERAL DISCUSSION / OFF TOPICReplies: 2Last Post: 14th May 2017, 08:59 PM -
Compact Workpiece Clamps for the face plate and angle plate.
By metaler in forum METALWORK PROJECTSReplies: 0Last Post: 10th Oct 2016, 07:16 AM -
Bronze Age Tools
By Robson Valley in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 0Last Post: 9th Dec 2014, 05:47 PM -
Bronze bush. What type of bronze?
By simonl in forum METALWORK GENERALReplies: 23Last Post: 5th Oct 2011, 09:40 PM -
tig for silicon bronze
By bloggs1968 in forum WELDINGReplies: 3Last Post: 10th Apr 2011, 03:43 PM
