Results 1 to 8 of 8
    Jul 2011
    Adelaide
    837
    Default Clipsal switch from Waldown or similar
    Hi All
    I am looking for a switch like the one in the photo. Either single or three phase would do.IMG_20181129_094309.jpg
    Eric
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    I have one that looks like this -
    the base is around 85mm by 65mm
    Jul 2011
    Adelaide
    837
    The original is 80 x 50 with a vertical pair of mounting holes 60mm apart. That could work. What mounting holes does it have?
    Eric
    Oct 2011
    59
    6,559
    Here is the switch without the cover. Holes in the switch for mounting are 6mm diameter (for a 3/16" screw?) and are 3/4" horizontal displacement and 2 5/8" vertical.
    Jul 2011
    Adelaide
    837
    Michael,
    I don't much want to drill the casting a set of offset holes. Thus for the moment I will keep looking for something with mountings more like the original.
    Eric
    Jul 2011
    Adelaide
    837
    IMG_20181217_090100.jpgJust for completion. I managed to find a new old stock bakelite HPM 250v 5A single pole switch that fits the mounting of the older Waldown's without modification. I am still on the lookout for an original but this should work for the years it may take to complete that task.
    Jul 2014
    melbourne
    110
    that's a beautiful drill, its a shame when you cant find the correct style and type of switch to match the drill to keep it original
    i had the same problem with a old power hacksaw, but luckily i found a switch at the local scrap yard , i will keep a eye out for one for you
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by dodge at4 View Post
    My sentiments exactly! I went to some effort to keep the housing looking original as it had been previously hacked so an original switch would be much appreciated. Thank you for keeping an eye out.
    Here a a few after and before photos. I put in threaded inserts where tek screws had held on a plate to cover the switch hole and were large holes had been drilled for conduit mounting.
    IMG_20181209_224214-1.jpgIMG_20181211_195621.jpgIMG_20181210_120926.jpgIMG_20181209_182034-1.jpgIMG_20181210_120929.jpg
  1. Switch Enclosure- Switch Position Identification.
    Last Post: 19th Jul 2016, 11:00 AM
  2. Need a 300mm caliper or similar
    By Michael G in forum WANTED TO BUY
    Last Post: 24th Jan 2016, 07:49 PM
  3. any one know which lathe this is ? look similar to the Lorch
    By thorens in forum METALWORK GENERAL
    Last Post: 27th Oct 2013, 08:44 AM
  4. Lathes similar to AL320G
    Last Post: 25th Nov 2011, 08:25 PM
  5. 9x20 and similar lathes
    By Big Shed in forum METALWORK GENERAL
    Last Post: 8th Sep 2011, 09:45 AM
