Results 1 to 5 of 5
Thread: Parallel Flange Channel
22nd Nov 2018, 07:49 PM #1Philomath in training
- 6,542
I should really get around to making up a stand I've been promising myself for several years now. To do that I need around 4.5m of PFC, either in the 75x40 size or the 100x50 size. Before I raid the local steel place, has a member in Adelaide got any surplus? It will cut up into lengths 650mm long or less, so short lengths are quite alright.
22nd Nov 2018, 09:56 PM #2Most Valued Member
- 5,945
Does it have tp be PFC, can you get away with tapered flange?
22nd Nov 2018, 10:22 PM #3Philomath in training
- 6,542
I need the height (say 80 to 100mm) as it is just to lift something up that much. I didn't see TFC in that size when I checked some catalogues.
23rd Nov 2018, 10:45 PM #4Most Valued Member
- 5,945
Hi Michael, if you can email me the sizes you need I'll have a look and see what I can find for you. From memory it's 100 X 50.
Will it matter if it has joins in it as there are a few shorter bits in the bin???
24th Nov 2018, 07:27 AM #5Philomath in training
- 6,542
Thanks Kryn. Shorter pieces don't worry me - I have the technology to join them. I'll send an email.
Historic factory tour YouTube channel
By variant22 in forum METALWORK GENERALReplies: 5Last Post: 19th Sep 2013, 03:43 PM -
Flange
By Scott in forum METALWORK GENERALReplies: 8Last Post: 3rd Jan 2012, 06:53 PM -
Welding flange on axle
By MillWeld in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 20th Feb 2011, 12:15 PM -
Best way to cut colourbond channel
By Sterob in forum METALWORK GENERALReplies: 15Last Post: 7th Feb 2009, 04:24 PM -
Parallel Set?
By John H in forum METALWORK GENERALReplies: 6Last Post: 7th Jul 2008, 08:43 PM
