Results 16 to 19 of 19
Thread: Sterling Drill Press Spindle
6th Nov 2018, 05:12 PM #16Most Valued Member
- 4,887
I think that I have sold the machine as is but not sure if they may want all of it or just the head , it was only $60.00 complete.
10th Nov 2018, 10:53 AM #17human termite
- Jul 2007
- sandstone point queensland
- 69
- 182
how do I get the spindle out? thanks,,,,,,,,,,,,,,bob
10th Nov 2018, 07:36 PM #18Member
- May 2007
- NSW
- 51
HI Bob, firstly. Lock the spindle when its all the way up, either by tightenning the 2 bolt on the front of the quill or by the depth stop. While holding the return spring cover or knob.loosen the nut of the handle shaft. Then slowly turn the spring cover to release the tension of the spring. Do not remove the cover and spring. Then pull the handle shaft out.. loosen the two bolt on the quill while holding the spindle assembly. Then you can pull spindle out.
Sent from my SM-G930F using Tapatalk
10th Nov 2018, 09:39 PM #19human termite
- Jul 2007
- 69
- 182
thankyou ,will send a photo with measurements when I get it out .....................bob
Can The Spoke Section Diameter Of A Drill Press Spindle Be Reduced By 0.2mm
By thumbsucker in forum METALWORK GENERALReplies: 9Last Post: 12th Aug 2015, 11:27 PM -
Waldown type H drill press info reqd. (spindle lubrication)
By johntopp in forum METALWORK GENERALReplies: 2Last Post: 18th Nov 2014, 03:56 PM -
Richarson drill press spindle
By chalmers888 in forum METALWORK GENERALReplies: 9Last Post: 24th Apr 2013, 10:16 PM -
By bwal74 in forum METALWORK GENERALReplies: 2Last Post: 19th May 2012, 06:21 PM
