Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Jun 2007
    sydney ( st marys )
    64
    4,890
    I think that I have sold the machine as is but not sure if they may want all of it or just the head , it was only $60.00 complete.
  2. #17
    Jul 2007
    sandstone point queensland
    69
    182
    how do I get the spindle out? thanks,,,,,,,,,,,,,,bob
  3. #18
    May 2007
    NSW
    51
    HI Bob, firstly. Lock the spindle when its all the way up, either by tightenning the 2 bolt on the front of the quill or by the depth stop. While holding the return spring cover or knob.loosen the nut of the handle shaft. Then slowly turn the spring cover to release the tension of the spring. Do not remove the cover and spring. Then pull the handle shaft out.. loosen the two bolt on the quill while holding the spindle assembly. Then you can pull spindle out.
    Sent from my SM-G930F using Tapatalk
  4. #19
    Jul 2007
    69
    182
    thankyou ,will send a photo with measurements when I get it out .....................bob
  1. Replies: 9
    Last Post: 12th Aug 2015, 11:27 PM
  2. Waldown type H drill press info reqd. (spindle lubrication)
    By johntopp in forum METALWORK GENERAL
    Last Post: 18th Nov 2014, 03:56 PM
  3. Richarson drill press spindle
    By chalmers888 in forum METALWORK GENERAL
    Last Post: 24th Apr 2013, 10:16 PM
  4. Sterling Drill Press
    By bwal74 in forum METALWORK GENERAL
    Last Post: 19th May 2012, 06:21 PM
