Results 1 to 11 of 11
29th Aug 2016, 07:19 PM #1Intermediate Member
- Jan 2016
- Brisbane
- 27
- 33
Shielded Cable 4core 1.5mm^2/2.5mm^2
Just looking if anyone has some shielded cable suited for a vfd or servo drives.
If not, does anyone need some (in the case I find a cheap roll)?
29th Aug 2016, 09:53 PM #2Senior Member
- Apr 2013
- Toowoomba Qld
- 401
I'm going to need some in the coming weeks, can't say that I really gave it much thought before now, just figured would go down to the local electrical wholesaler that sells cable by the meter and pick some up.
I need a whopping 1m length.....
Let us know how you go on your search, just did some quick reading and turns out there is some difference between "normal" cable and good stuff for a VFD
Why High Performance VFD Cable is Important
29th Aug 2016, 10:18 PM #3Member: Blue and white apron brigade
- 7,182
I'm not suggesting not to bother with shielded cable but I just want to relate my experience with shielded cables and radio noise in my shed.
When I first set up my shed I setup a 1970's era stereo system and the more VFDs I set up in the shed the worse the radio reception for certain AM stations got.
Because the shed is Colorbond using an external antenna improved radio reception but it made no difference to the noise.
I tried shielding the cable between the VFD and motor cable on the VFD closest to the radio but found it made very little difference to the radio noise.
After much mucking about I worked out that most of the noise was reflecting back down the mains line.
I tried using one of those computer mains cables with a magnetic filter on it but that also made little difference.
The more VFDs I left turned on the worse the radio noise even if the motors were not running, but with the motors running the noise was worse again. 3 VFDs switched on and one motor running was enough to kill radio reception at the low end of the AM band.
I got around the radio noise problem by getting a digital radio which does not seem to be bothered by the VFDs.
It would be interesting to know from any members if they have had noise problem.
I believe there is at least one member who had a wifi problem with a VFD but I don't know how it was resolved.
29th Aug 2016, 10:20 PM #4Intermediate Member
- Jan 2016
- Brisbane
- 27
- 33
I'm probably over-thinking the shielding for my entire build, but without an in-depth knowledge of electrical systems I'm going to try eliminate interference as much as possible
Probably heading to J.R Turk in a few days to get some advice and cable, just thought if anyone here had some to shift.
EDIT: Posted without seeing previous.
Shielding in my case is for ac servos, encoders. Small CNC conversion.
29th Aug 2016, 11:07 PM #5
One of the more relevant issues with VFD noise in a workshop is that it interferes with digital measuring gear. On my mill, the low end DROs go completely random without shielding of the motor cable. Shielding of the DRO cables helps a little, but at certain settings of the VFD the DRO switches on and off and display random mumbers between -16,000 and +16,000mm Shielding both has fixed it.
My machines are too noisy to listen to radio, so I've never tried that ....Cheers, Joe
30th Aug 2016, 08:03 AM #6Philomath in training
- 6,540
I asked a local industrial electrician if he had any and got a couple of offcuts for free (I had recently got them to do some work admittedly).
Better to only do things once and as recommended rather than have to do it again when the neighbours/ other half complains.
30th Aug 2016, 06:22 PM #7Senior Member
- Apr 2013
- Toowoomba Qld
- 401
So I went out looking to get some today as was out getting some bolts, turns out that it is harder to find then I thought, one of the electrical wholesalers said they could order it in but didn't seem real keen and didn't even bother to give me a price.....
Side note, they appear to be referred to everywhere as VSD or EMC cables
30th Aug 2016, 07:20 PM #8Intermediate Member
- Jan 2016
- Brisbane
- 27
- 33
There are a few online retailers: https://www.eltech.com.au/product-ca...cable-screened
Treotham Automation - Supplier of Quality Electrical & Mechanical Components - Treotham
http://electriciansupplies.com.au
All around $3-$8 depending on conductor size.
Someone posted on CNCZone abotu this seller, Evolution Cables and Connectors - Flexible Cable Specialist. Brisbane Queensland Australia - Variable Speed Drive Cables, and they have the dual shielding I like.
1st Sep 2016, 12:09 PM #9Senior Member
- Apr 2013
- Toowoomba Qld
- 401
Just updating post for reference for anyone that cares
Ended up getting some cable this morning
Went through L&H Electrical
Lawrence & Hanson – Electrical Wholesaler Australia 01 home - Lawrence & Hanson - Electrical Wholesaler Australia
They had the Kabeltec Flex-CY-JB in 4x2.5mm2 in stock
Productdetail - Kabeltec Englisch
Was about $5 /m as a walk in, retail customer, sold by the meter
Good looking cable, pretty flexible so I think it should work pretty well. The Evolution cables linked above look to have better shielding but I think still stuff will do just fine.
1st Sep 2016, 10:34 PM #10Intermediate Member
- Jan 2016
- Brisbane
- 27
- 33
In terms of connectors what kind could I use to 'connect' the split cable shielding so I can terminate it in one place (plastic case idea) as I would prefer to not run glands and cables through to a terminal block.
I only know the basics like audio, cinch style, D-Sub, nothing certain that I know connects to the shielding (braided or foil).
6th Sep 2016, 11:39 AM #11Most Valued Member
- 4,255
Shed Cable Clips
By DSEL74 in forum METALWORK GENERALReplies: 2Last Post: 20th Dec 2015, 06:47 PM -
Cable Damascus
By DSEL74 in forum THE SMITHYReplies: 9Last Post: 17th Dec 2015, 08:11 PM -
Does this cable contain Asbestos?
By variant22 in forum METALWORK GENERALReplies: 8Last Post: 24th May 2015, 11:04 AM -
"bendex" cable end
By Briangoldcoast in forum METALWORK GENERALReplies: 9Last Post: 19th Apr 2015, 09:19 AM -
VFD Remote Cable
By Oldneweng in forum METALWORK GENERALReplies: 18Last Post: 14th May 2014, 07:39 AM
