Results 1 to 6 of 6
Thread: 80mm Round Galvanised tube
13th Aug 2016, 11:36 AM #1
Looking for some 80mm round galvanised tube with a wall thickness of 2.5-3mm.
A piece 85mm will get me started, but will take more if available.
Want to make a security lock for the king pin on my 5th wheeler.
13th Aug 2016, 01:02 PM #2Pink 10EE owner
- 6,216
13th Aug 2016, 03:06 PM #3
Thanks RC, it appears hat the one I looked at (80mm diam) is an Imperial nominal 3". The 65mm NB would be too small an ID and the next size up 80 NB would be too large an ID.
The one I looked at had an ID of about 75mm.
Hoping that someone would have a bit of Imperial pipe kicking around.
13th Aug 2016, 05:47 PM #4
Hi Fred,
I'm fairly sure I have some 3" gal pipe bits you can have.
However, I wont be home to check until Monday night. If not more urgent, give me a call on Tuesday.Cheers, Joe
13th Aug 2016, 06:18 PM #5
Thanks Joe, will give you a call on Tuesday.
13th Aug 2016, 08:45 PM #6Most Valued Member
- 5,942
If you can't find a piece the correct size, I've used a size that was close, cut a piece out and then welded it after clamping to size. Have also had it where I fitted a piece in to make the size.
Scalloping round tube/pipe for T joints
By th62 in forum METALWORK GENERALReplies: 8Last Post: 7th Nov 2013, 04:21 PM -
Gedore 80mm Ratchet Ring Spanner
By Pat in forum METALWORK GENERALReplies: 8Last Post: 1st Nov 2012, 10:47 PM -
A little bit of galvanised steel tube
By springwater in forum METALWORK GENERALReplies: 11Last Post: 15th Mar 2011, 08:36 PM -
DONE: Underwood, industrial Round Tube cutter
By Dano48 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 20th Nov 2010, 04:56 PM -
Drilling 80mm aluminum tube
By warren in forum METALWORK GENERALReplies: 6Last Post: 5th Sep 2006, 09:22 PM
