Results 1 to 5 of 5
Thread: 6mm or 1/4" square push broach
11th Aug 2016, 09:10 PM #1Philomath in training
I want to make some square holes to hold 6mm or 1/4" HSS. I could file them , but a square push broach sounds more sensible. If any one has a lead on one...
11th Aug 2016, 10:55 PM #2Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
If they are through holes I could wire EDM them. PM me if your interested.
11th Aug 2016, 11:45 PM #3Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Is the weekend too late to have a look at what sizes I have.
Phil
12th Aug 2016, 08:16 AM #4Philomath in training
Thanks Ash. I'll bear that in mind but as a last resort as there would be several of these.
No rush - one of a list of many things to look at
The added bit - In case I've mislead anyone, I have broaches for square keyways. The broach I'm chasing is for making square holes
MichaelLast edited by Michael G; 12th Aug 2016 at 07:29 PM. Reason: added a bit
12th Aug 2016, 11:30 PM #5Most Valued Member
Hi Michael,
Have seen where one was made, from memory a piece of square steel was used and a course thread was cut on it up to about 3/4 of its length. It was then put on a surface grinder and ground down with a taper starting at the threaded end on all 4 sides, the shallow end has the first thread ground off so that it drops in the hole. The whole thing is then heat treated to be able to work. Once that is done, it should be ready to use.
Found the link //metalworkforums.com/f65/t1993...-square-broach
KrynLast edited by KBs PensNmore; 12th Aug 2016 at 11:34 PM. Reason: Found the link
DIY square broach
By bob ward in forum METALWORK GENERALReplies: 3Last Post: 18th Jun 2016, 11:43 AM -
Keyway broach 3/16
By Greolt in forum METALWORK GENERALReplies: 11Last Post: 30th Mar 2016, 09:38 PM -
Rota broach annular cutter info
By Bill13 in forum METALWORK GENERALReplies: 33Last Post: 6th Feb 2016, 10:58 AM -
Fein magnetic broach core drill
By Marc in forum METALWORK GENERALReplies: 14Last Post: 26th Jan 2015, 09:27 PM -
Metric Pulley Keyway Broach
By electrosteam in forum METALWORK GENERALReplies: 24Last Post: 20th Nov 2009, 10:09 PM
