Results 1 to 9 of 9
    Feb 2012
    Sydney
    61
    Default Wanted: Milling Machine
    G'day guys,
    i am currently in the market for a small milling machine in the sydney area. Preferably single phase but i could use a 3 phase unit with a vfd. Looking for something slightly better than the round post mills that H&F sell. Any leads would be greatly appriciated.
    Shane.
    Sent from my SM-G930F using Tapatalk
    May 2011
    Murray Bridge S Aust.
    5,959
    Do you have a particular work size envelope in mind? What sort of Dollars are you prepared to go to, Shane? With/out tooling, type of tooling? No point in telling you about a $4000 one, when you want to spend $500? Answering these, would get you a machine closer to your requirements.
    Feb 2012
    Sydney
    61
    Fair Comment Kryn,
    My budget is around $1000, ideally i would like some basic tooling but not a deal killer.
    May 2011
    5,959
    Hi Shane,
    For that sort of money, this is about all you'll get, Mini Milling Drilling Machine in NSW | eBay. Another one requiring all the electrics, Mini MILL Hafco HM10 in NSW | eBay, set it up with a small 3ph and Inverter could be a good machine.
    Very small work surface, it's OK if you want it for model making. I had one till my brother wanted it back, I couldn't get it into the boot of the car quick enough.
    The gears are plastic, metal ones are available, but they broke also. Tramming them is no problem, keeping it in tram is another, without a bit of fabrication work, can load pics of what was done, if needed. For something half decent with out it being clapped out, I try to save another $1k, Ebay has them running from $1500 minimum upwards. The other thing I forgot to ask was did you want a vertical or horizontal mill as there is a lot of difference in the capability of the machines. To set up a decent mill with tooling could be another $1k, depending on the type of tooling, a decent machine vice $350 used, NT30 tooling arbor probably $75.00 each and on it goes. I know, I've been looking for something better than the "TOY" mill.
    Hope this helps a bit, sorry to be a bit of a downer, but thought I'd let you know. Don't get me wrong, if it was for a model making mill, it would be acceptable, but without knowing what you are wanting to do on it, making it difficult to answer. On gumtree Moama 2731, NSW | Gumtree Australia Free Local Classifieds
    Feb 2012
    Sydney
    61
    hey Kryn, I thought i would update this. I ended up spending $2200 on the mill. It is in brand new condition with collets and heaps of endmills.
    May 2011
    5,959
    Thanks for the update, very nice indeed. What make is it and where did you acquire it from? Interested, as it's in my price range for a present to myself next year.
    Feb 2012
    Sydney
    61
    It was a gumtree purchase, It is 15 years old. It was originally from hare and forbes.
    May 2011
    5,959
    Crikey, looks brand new . Still wouldn't mind knowing what model it is, please.
    Feb 2012
    Sydney
    61
    It is a HM40.
  1. Milling machine
    By lamestllama in forum METALWORK GENERAL
    Last Post: 21st Jun 2019, 06:02 PM
  2. HM 46 milling machine
    By leroy in forum METALWORK GENERAL
    Last Post: 19th Oct 2012, 05:20 PM
  3. Used Milling Machine
    By woodfast in forum METALWORK GENERAL
    Last Post: 15th Apr 2012, 10:07 PM
  4. Milling machine
    By paulj in forum METALWORK GENERAL
    Last Post: 8th Oct 2011, 10:14 PM
  5. Milling Machine
    By R W in forum METALWORK GENERAL
    Last Post: 17th Mar 2011, 09:02 PM
