Results 1 to 4 of 4
Thread: NT30 ER40 Chuck
    Apr 2009
    Kingswood
    930
    Default NT30 ER40 Chuck
    I have just acquired a couple of new 1" Sutton end mills with threaded ends, and no chuck to hold them.
    I see listed in the catalogs ER40 collets 25/26 mm that could be the way to go.
    John.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    That will work, also have a look for BT30 chucks as well,they are usually cheaper than the NT30.
    You would need to make a longer draw bar though.
    near Rockhampton
    6,218
    You can get bigger ER40 collets then 26mm as well. Up to 28 or 29mm I think.
    Also you will find you will only be able to take light cuts with such big endmills. They are large endmills for an ISO30 spindle. But handy when you need a large endmill.
    Mar 2014
    South of Adelaide
    1,227
    The other way is to make adapter that screws onto the bt30 arbor to make up the length, that is how i do it and it works well. I think you can actually buy the adapter.
  1. ER40 collet chuck for 260???
    By ventureoverland in forum THE HERCUS AREA
    Last Post: 27th Sep 2014, 11:21 AM
  2. D1-6 ER40 collet chuck
    By Ueee in forum METALWORK GENERAL
    Last Post: 7th Nov 2013, 11:26 PM
  3. Er40 Collet Chuck
    By localele in forum THE HERCUS AREA
    Last Post: 21st Jan 2012, 08:47 PM
  4. ER40 Collet Chuck for a lathe.
    By aametalmaster in forum METALWORK GENERAL
    Last Post: 6th Jun 2011, 08:29 PM
  5. ER40 chuck for lathe spindle
    Last Post: 6th Nov 2010, 03:28 PM
