Results 16 to 24 of 24
25th Apr 2019, 08:36 PM #16New Member
- Apr 2019
- UK
- 8
I have tried to post a link to show you what I am trying to replicate but it's not appearing....
if you google Stuart Stockwell Silver Six Oak and look at how the it works, that's my challenge!
25th Apr 2019, 09:15 PM #17Most Valued Member
25th Apr 2019, 09:22 PM #18Most Valued Member
Looks like it could be ½” aluminium tube. Perhaps a pair of roller bearings are inserted into the tube?
25th Apr 2019, 11:14 PM #19New Member
- Apr 2019
- UK
- 8
25th Apr 2019, 11:24 PM #20Philomath in training
- 6,540
Rather than rolling element bearings, a Teflon bush and pin?
26th Apr 2019, 01:50 AM #21New Member
- Apr 2019
- UK
- 8
If the brushes allowed free rotation, would that be easier than something with bearings?
Is there anything I could repurpose, a rod or tube which already has a rotating joint?
1st May 2019, 01:32 AM #22Senior Member
- Apr 2019
- Finland
- 46
- 117
That could be done with rod and pipe compination.
Shorter rod, than the pipe. Is goin to placed inside the lower part. 10mm pipe with 2mm wall and 8mm rod inside it.
Longer rod inside the upper part. Plug welds to other ends to keep pieces together. That gives nice look.
Groove to upper parts rod can be easily done with die grinder with tungsten carbide cutter, or just angle grinder using 4mm thick cutting/ grinding wheel.
1st May 2019, 10:53 AM #23Gear expert in training
- 34
- 1,075
1st May 2019, 02:44 PM #24Senior Member
- Apr 2019
- Finland
- 46
- 117
300 hours to make this thing ?
By steamingbill in forum METALWORK GENERALReplies: 5Last Post: 23rd May 2017, 01:49 AM -
Does my drill have a rotating head?
By Legion in forum METALWORK GENERALReplies: 19Last Post: 11th Apr 2016, 12:08 PM -
Wanted: 20m or taller steel street light pole....
By jhovel in forum METALWORK GENERALReplies: 78Last Post: 19th Nov 2014, 08:53 AM -
This a good thing or a bad thing?
By Old Hutcho in forum METALWORK GENERALReplies: 17Last Post: 5th Jan 2014, 05:36 PM -
How do I make one of these (long thin metal thing)
By Arron in forum METALWORK GENERALReplies: 17Last Post: 7th Sep 2013, 04:31 PM
