Results 1 to 1 of 1
12th Apr 2019, 06:46 PM #1Senior Member
- Apr 2019
- Finland
- 46
- 117
Disc sander from crappy wood chipper.
Hi
I bought an old wood shredder couple years ago.
Paid 30$ from it.. and soon i realized that it really wasn't
good at all.
Its desing didn't work at all with fresh wood, where i wanted to use it in first place.
Bought a new one and this was stored to my shed and forgotten. Found it after two years and decided to repurpose it.
As an disc sander.
I wanted to use it with angle grinder wheels.
It has 2000w motor, and it runs 4200rpm.
So, it was perfect for little rougher material removing.
Blade was mounted to axle, which has M22 thread.
Angle grinder wheels and bads are here with M14 thread.
So that needed to be fixed.
I had no lathe, so i did "turning" manually.
For better and easier use. I made an locking latch for the other end of the axle. That makes changing wheel easier, when you can lock the axle, and then open the locking screw of the grinding wheel using only one key.
Made a new casing and re-shaped the original door.
It can be used with flap wheels, fibre discs and "velcro" papers. It can be used with 180mm wheels and 205mm backing for papers.
Door can be opened, and when its closed it works as a guard.
Motor doesn't start when door is unlocked, so it had a good safety option allready.
Reused old feets from the original shredder.
But those are temporal. I will mount it to the table,
when i have finished my workshop rebuilding process .
Video about the building can be seen here:
https://youtu.be/ZdHxi0XZSvM
Disc sander build
By Pete O in forum METALWORK PROJECTSReplies: 10Last Post: 11th Jan 2019, 03:31 PM -
Disc and belt sander
By Maxi77 in forum METALWORK GENERALReplies: 32Last Post: 26th Jun 2015, 10:17 AM -
20 inch Disc Sander
By 4-6-4 in forum METALWORK GENERALReplies: 25Last Post: 8th Jun 2012, 10:04 PM -
Replacing Worn Out Belly Pan in 18" Wood Chipper
By Acco in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 5th Jan 2012, 11:46 PM
