Results 1 to 11 of 11
Thread: Gmf bench grinder resto
11th Apr 2019, 10:22 PM #1Member
- May 2007
- NSW
- 51
Got this together with the waldown drill press from the previous post. Pics is before and after , put new bearings, sandblast/ hammered blue finish and a stand from an old drill press , new tilting work table for the sander.
Sent from my SM-G930F using Tapatalk
11th Apr 2019, 11:26 PM #2Most Valued Member
- 5,942
Very nice, thanks for the pics of before and after. Nice to see a drill press base being used for a grinder base also, wouldn't have thought of that one.
12th Apr 2019, 12:00 AM #3Senior Member
- Apr 2019
- Finland
- 46
- 117
Very nice looking result.👍
Are you still able to adjust the height of the drill press table? Or move sideways? Or is the grinder too heavy that it wouldn't be reasonable?
Sorry for asking so much.
I just got an idea from this.. but i'm not sure should i continue thinking, or should i forget the whole idea.
Nice work you have done!
12th Apr 2019, 05:28 AM #4Member
- May 2007
- NSW
- 51
12th Apr 2019, 03:19 PM #5Senior Member
- Apr 2019
- Finland
- 46
- 117
Thank you, i know that the table is stable and sturdy. There's no doubt from it.
I asked about the weight.
Because i was wondering, that could it be possible to open the latch with one hand, holding the weight with another..
Then lower the stand and tighten the latch.
I have been planning to make tilting belt sander for myself, i would like to have height adjustment in it.
That kind of stand would possibly work with it.
But now i realized that gas spring added to the stand, under the grinder could help with the weight, if needed.
I ask sometimes weird questions, i hope that doesn't bother.
Usually it happens, that at the moment i make a question, answer pops to my mind.
But if i don't ask.. That doesn't happen.
That's why i asked. I already know where i can find cheap drill press stand.
Thank you for the inspiration.
12th Apr 2019, 04:44 PM #6Member
- May 2007
- NSW
- 51
Im with you. I tried what you said, lowering bit by bit is fairly ok but to adjust it up is a bit of struggle. I have attach a pic of a stand i made before .
12th Apr 2019, 05:54 PM #7Senior Member
- Apr 2019
- Finland
- 46
- 117
Nice!
That really is a working stand too!
12th Apr 2019, 07:13 PM #8Most Valued Member
Nice work. I have exactly the same GMF grinder.
13th Apr 2019, 06:31 PM #9
LUV GMF .
I reckon they are the Rolls Royce of bench grinders.
The one we had a school got virtually no attention but ran for years.
When switched off it would run on for a few minutes. Is there a currently made bench grinder that will do that?
I have not seen one for sale up our way?
14th Apr 2019, 07:43 PM #10
14th Apr 2019, 08:51 PM #11Most Valued Member
No Grahame, mine's 3 phase 415V. So maybe it's not exactly the same after all. Same same, but different.
I keep threatening to put a VFD on it so I can reduce the speed. The Multitool linisher seems to run way faster than it needs to.Chris
Ultimate Bench Grinder
By YBAF in forum GENERAL DISCUSSION / OFF TOPICReplies: 6Last Post: 16th Sep 2016, 08:30 PM -
bench top for a bench grinder
By wodstok in forum METALWORK GENERALReplies: 1Last Post: 24th Jan 2011, 03:04 PM -
8'' bench grinder issue
By mistercartoon in forum METALWORK GENERALReplies: 17Last Post: 10th Aug 2010, 04:19 PM -
Bench grinder problems
By new_guy90 in forum METALWORK GENERALReplies: 5Last Post: 7th Feb 2009, 02:45 PM -
Which 200 mm bench grinder should I buy ?
By Retromilling in forum METALWORK GENERALReplies: 15Last Post: 16th Oct 2008, 11:31 AM
