Results 1 to 12 of 12
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,540
    Default The things you do...
    Some time ago, I made a bench grinder grinding rest for a guy in Country SA. Not sure how I got onto it - I might have been looking for something on Gumtree, saw his ad looking for parts and offered to help as you do.
    Anyway, I got a call in August while in Tas asking if I could make something else up for him. Yeah why not - but it would have to wait until I was back in Adelaide etc etc.
    Fast forward. I'm back*, so Paul makes contact again as as he was in town, drops in the item. A pair of favourite sunglasses. The wings are plastic, the frames metal and the place where the screw fastens has broken. Can I make up a new pair of wings?
    Crumbs.
    This is one of the wings. Around 110mm long, ends are diameter 5mm, middle is around 3mm diameter.
    After a bit of thought, I decided that the new wings would need to be stainless. Paul did not want plastic and Al would probably leave grey marks. I had some 5mm stainless rod, but how to get the hourglass shape? The length and depth of the dip was such that the radius would be around 1.6m. Eventually I worked out that holding the rod in the battery drill at a slight angle (probably about 15 degrees) on the round drum of the linisher would sand out that part. Bit of a polish on the lathe and it looks about right.
    Now the hard part. I measured the screw and discovered that it was 10BA. For those that are not familiar with BA threads, that is around 1.5mm OD, with a proportionally small pitch. My BA taps are old and so I was not sure about tapping into SS, so I used a pin reamer to ream out a 2mm hole and put a brass plug in (loctite bearing retainer compound). I then had to drill out a 1.4mm hole for the tapped hole. For that I used my smallest chuck and a sensitive drilling attachment on the mill, run at high speed. It works by holding the knurled disc and using that to guide the drill up and down. Usually used on a drill press, I used it on the mill so I could clamp everything down and line things up with the microscope.
    To tap, I removed the chuck from the mill, put in the tap and used that as a tapping chuck as every other tapping device was too big. Effectively tapping with a lever arm of around 1/2", and I could feel every little catch/ notch... Got there!
    Tomorrow I need to clean things up, put a slot through the end and I will (hopefully) have some wings sans bends. Not sure what to do there, as the plastic has some natural spring. The stainless will sit there so may not be as comfortable. The other issue is that with the non-uniform cross section, any bending will have to be done carefully as otherwise it will bend only at the thinnest point. I may have to wait for Paul to get back and adjust the fit.
    *I should point out that the job I came back for has now been terminated. Bit of bait and switch, bit of parachute someone into the position over the objections of the direct manager and of course he won't sabotage the position...
    May 2011
    Murray Bridge S Aust.
    5,942
    Does that mean that you're on the lookout for another job???
    Oct 2011
    59
    6,540
    I am looking for more paid employment. My wife and others have found plenty of jobs for me in the meantime - like this one.
    6,439
    Hi Michael,
    I enjoy reading your posts and often learn something new !
    Who says that you can't teach an old dog new tricks
    Sorry to learn about the job though ! I found myself in a similar position some forty odd years ago, two young children and jobs scarce. At the time the government was running educational schemes, where in return for a subsistence allowance you agreed to go, basically back to school, in my case I ended up at a technical collage and then moved on to university.
    The upshot of this was that I got a job managing a computer company supplying schools with computer systems. About a year later the company collapsed, so I started my own business, and that is where I remained until retiring a few years ago.
    I suppose what I'm saying is take advantage of the skills that you have.
    May 2011
    5,942
    I am looking for more paid employment. My wife and others have found plenty of jobs for me in the meantime - like this one. Michael
    BUMMER, if things got desperate, would you go back to Tassie?
    Hope something comes up real soon for you. Trouble is, the odd jobs don't really help pay the bills.
    Nice work by the way.
    Oct 2011
    59
    6,540
    So we don't get too far off topic,
    ...if things got desperate, would you go back to Tassie?
    see //metalworkforums.com/f265/t202...74#post1947574
    Oct 2011
    59
    6,540
    It worked (sometimes I can even surprise myself). The only problem may be that the wings are heavier than the plastic ones would be but
    jatt's Avatar
    jatt is offline Always within 10 paces from nearest stubby holder
    Bendigo
    51
    760
    Bugger you aren't in central Vic. Someone who can think outside the box and is handy with machine tools would go well around here!
    Can train most people how to drive my equipment, but I cant teach folk how to think!
    One thing I can tell you is that a lot of employers have a similar issue. Some has a thing against "more mature folks", but I find older folk are generally a good bet mainly because of the experience they bring. If they of course they are prepared to learn new skills and can handle a younger person telling them what to do.
    Frisky wife, happy life. ​Then I woke up. Oh well it was fun while it lasted.
    From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
    May 2011
    5,942
    Quote Originally Posted by jatt View Post
    If you can teach that, you'll be a multimillionaire!!!!!
    My grandkids are older than the bloke I work for!!!
    6,439
    That is what Universities are good at ! That is teaching you how to think, how to discover useful information !
    In my experience few mature people can handle that, many younger ones can't either !
    Nov 2010
    Gippsland Victoria
    733
    Default Sensitive Drill
    I liked the sensitive drill jig.
    Am guessing its a firm sliding fit of a bar in a tube, with a couple of slots in a tube and a cross bar going through the slots and the sliding bar. Or is it something far simpler ?
    If the bearing ever fails are you suddenly holding a thing that is whizzing around at 1000s of rpm ?
    Bill
    Oct 2011
    59
    6,540
    That's basically it (with a spring to counterbalance the weight). If the bearing did jam then yes, you would be holding a knurled whizzing thing.
  1. Looking for things to do...
    By S.S. in forum G'day mate - THE WELCOME WAGON -Introduce yourself
    Last Post: 18th Nov 2016, 01:52 PM
  2. Some things do last!
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 7th May 2014, 06:39 PM
  3. The things I buy III!
    By Stustoys in forum METALWORK GENERAL
    Last Post: 19th Jun 2012, 12:02 PM
  4. The things I buy II!
    Last Post: 9th May 2012, 11:36 PM
  5. The things I buy!
    Last Post: 8th Oct 2011, 12:10 AM
