Results 1 to 9 of 9
20th Feb 2019, 02:00 PM #1Member
- Nov 2018
- Tasmania
- 97
Homemade Quick Change Gearbox Complete
I've finally finished my quick change gearbox for my lathe!
It's been a 8 month long project from design to completion
Designed from scratch, made from scrap!
I have a build series on youtube https://www.youtube.com/playlist?lis...qmbdWe3U7kc-MX
20th Feb 2019, 05:06 PM #2Most Valued Member
- 2,672
Awesome effort - well done!
20th Feb 2019, 08:40 PM #3Most Valued Member
Impressive!
20th Feb 2019, 08:43 PM #4
Hi Tommy,
Very nicely done, I like the handle on the back ! Does it just turn the leadscrew ?Best Regards:
20th Feb 2019, 09:03 PM #5Member
- Nov 2018
- Tasmania
- 97
20th Feb 2019, 09:17 PM #6
Had a look at a couple of the U Tube vids.
CoolFrisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
22nd Feb 2019, 10:11 PM #7
Hi Tommy,
Very crafty ! I had visions of been able to quickly wind back the saddle via the leadscrew after threading.
Thanks for the pictures and explanation.Best Regards:
25th Feb 2019, 08:15 AM #8Member
- Nov 2018
- Tasmania
- 97
25th Feb 2019, 10:15 PM #9
Hi Tommy,
I own a Myford S7LB, and it can be a right royal pain fitting the winding handle down the spindle to wind back the saddle after threading, particularly for metric threads, and if I have the ER32 collet chuck and its drawbar fitted, I've seen me winding the chuck using the chuck key.
I don't know if it helps, but I made a "Tumbler reversing mechanism" with centre neutral for a milling machine table drive. That could get you away from a spinning handle.
Just to add clarity, I try to arrange things so that I'm threading away from the chuck if I can, particularly if I'm doing a blind internal thread.Best Regards:
quick change toolposts
By robyn2839 in forum METALWORK GENERALReplies: 0Last Post: 10th May 2017, 11:49 PM -
noisy quick change gearbox
By Com_VC in forum THE HERCUS AREAReplies: 10Last Post: 28th Apr 2011, 03:21 PM -
Quick Change Gearbox Problem
By Col2310 in forum THE HERCUS AREAReplies: 2Last Post: 12th Jan 2011, 05:19 PM -
Quick Change Gearbox gears
By Garry Edwards in forum THE HERCUS AREAReplies: 3Last Post: 6th Mar 2010, 03:47 PM -
Quick Change Toolpost
By nexusone in forum METALWORK GENERALReplies: 3Last Post: 2nd Jan 2008, 07:52 AM
