Results 1 to 1 of 1
8th Feb 2019, 02:25 AM #1New Member
- Feb 2019
- Rome
- 1
Aluminium 5000/6000 or S.S. 304 or S.S. 316 or HDP iron for balcony facing the sea?
Hi,
It's all day I'm surfing the web but I can't address the following questions. What is the best between
HDP galvanized iron
Aluminium alloy 5052 or 6063
Stainless steel 304
Stainless steel 316
for use in salt-water sensitive shore applications, to avoid rust and corrosion? Which one is going to last the most? How long each one is going to last presumably before starting to be rusty and ugly?
In particular I need to choose one of those material for each of the following:
* the posts that are going to hold the weight of the awnings
* new window grates
* bolts and screws
There are many more aluminium alloys for marine conditions but those above seems to be two cited the most. The others are
en.wikipedia.org/wiki/Aluminium_alloy -> Applications -> Marine alloys
https://www.boatingmag.com/marine-accessories-aluminum-vs-stainless-steel
https://en.wikipedia.org/wiki/Stainless_steel -> Applications -> Water
The Handyman 5000
By nearnexus in forum METALWORK GENERALReplies: 8Last Post: 12th Sep 2013, 06:27 PM -
Cast iron fireplace - Question for restoring using Penetrol & Liberon Iron Paste
By mookschank in forum METALWORK GENERALReplies: 8Last Post: 19th Jun 2013, 06:32 PM -
reg not facing the right way up?????
By 355tonner in forum WELDINGReplies: 14Last Post: 3rd Dec 2011, 07:48 PM
