Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: tap wrench
    Jul 2006
    Athelstone, SA 5076
    4,258
    Default tap wrench
    I asked about making one of these sometime back...thought it was time that I got off my backside and did something about it
    I am happy with the way it turned out.
    MrPete222 tip 393 video helped me out the calcs for milling the slot...worked a treat
    Oct 2010
    NSW
    181
    Nice one.
    Aug 2011
    4,779
    Good work. Nice knurling too.
    6,474
    Hi Eskimo,
    Very nicely done ! I've not seen one made quite like that.
    I do agree with Simon, the knurling looks really good, a nice sharp pattern.
    Jul 2006
    Athelstone, SA 5076
    4,258
    Hi Eskimo,
    Yeah...the knurling surprised me too
    Thanks Simon and Baron
    I copied "This old Tony"'s tap wrench...you tube it.
    Jun 2013
    Tasmania
    257
    Lovely work.
    What material did you use?
    I really need to consider making one, or buying a decent wrench. I've broken and cracked the cheap crappy ones I've had and they hold terribly and are made from cheese.
    Thanks.
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by Hornetb View Post
    Lovely work.
    Thanks.
    Handles were BMS but the jaws was from stuff a mate gave from his toolmaking days a few years ago...so I am guessing/hoping it might be good stuff so I can harden them?
    Nov 2004
    Bungama SA
    52
    960
    As soon as I seen your picture I thought of This old Tony
    Jul 2006
    Athelstone, SA 5076
    4,258
    And another...this time my version of a starret 174
    Yes you can see the end mill marks...but I intend to harden and grit blast and parkerise...so hopefully they should disappear....with a bit of luck
    6,474
    Hi Eskimo,
    Looks good ! Should be even nicer when you have treated it.
    I have a Starret one, its many years old. I keep meaning to remove the screw and put a hardened tip on it. Mine has mushroomed badly and will need to be filed to get the screw out. Another round toit I'm afraid, its somewhere in there
    Jul 2006
    Athelstone, SA 5076
    4,258
    Hi Eskimo,
    I had a small hardened dowl that I used
    6,474
    Hi Eskimo,
    Yes I really ought to pull it out of its hiding place and do something like that. I do think that its a weakness of this type of tap wrench. I used to have one that came in a box of taps & dies, the screw handle was made from monkey metal and broke off the first time I used it. I sawed it in half to release the tap before throwing it in the scrap bin.
    I currently use a similar one with a sliding "V" block.
    Jul 2006
    Athelstone, SA 5076
    4,258
    My version of the Starret
    Not finished ....have to do plunger and spring and bore and cut V in centre bit...etc
    6,474
    Hi Eskimo,
    That looks posh even unfinished I'm going to have to keep an eye on this one
  15. #15
    Jul 2006
    Athelstone, SA 5076
    4,258
    wonder what the plungers cost?..wondering if I should buy one in lieu of making one...If I buy I wont have to harden it
    would silver steel be okay to make the plunger and harden and temper afterwards?
    edit: they are US$6.22 each for this size...but will it fit?...as I have no idea if I am any where close to their dimensions..I just took a good picture form the web and expanded its size till it was about 9 inches in length...what I got is what I have shown.
  1. DIY Tap wrench
    Last Post: 31st Aug 2018, 06:37 PM
  2. Collet Nut Wrench
    By BaronJ in forum METALWORK GENERAL
    Last Post: 28th Aug 2015, 11:17 PM
  3. HIT Piipe wrench
    By WesP in forum METALWORK GENERAL
    Last Post: 24th Feb 2014, 09:09 PM
  4. Open end wrench as a caliper.
    By aametalmaster in forum METALWORK GENERAL
    Last Post: 9th May 2012, 12:39 AM
  5. Impact Wrench
    By electrosteam in forum METALWORK GENERAL
    Last Post: 27th Jul 2010, 11:52 PM
