Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Oct 2018
    Chandler, AZ
    44
    33
    Quote Originally Posted by MasterSpoon View Post
    Either some really good photography or some nice looking parts !
    Would make awesome desk toys for the office, are you making them to sell or just to show off to your friends / family ?
    Checking out the other clips on your youtube channel looks like you have had a few issues with birds nesting when at least doing the rough turning. Have you played around much with speeds & feeds and depth of cut to see if you can engage the chip breaker on the insert ? (or tried different chip breakers?)
    So far I wasn't really successful with breaking chips. I tried different speeds (3-6 m/s), feeds (0.1 - 0.4 mm/turn), and the depth is 0.25mm typically. I use aluminum CCMT/CCGT Korloy inserts. The chips always grow long. I can't go to a higher speed, I have 2x1 spindle pulley ratio. And it's quite nervous when spindle runs at 2k+ RPMs
    I use intermittent feed for drilling to limit the chip length. But not for turning.
    Could you advise a good approach for chip breaking?
  2. #17
    Oct 2018
    Chandler, AZ
    44
    33
    And yes, I'm making some for sale on ebay/etsy
  3. #18
    Oct 2018
    Chandler, AZ
    44
    33
    Quote Originally Posted by r3292c View Post
    Recommended conditions from Korloy are:
    1. Speed 100-200 m/min, and I'm running at 180-360 m/min - at max diameter, but also 40-60 m/min at say 15 mm diameter;
    2. Feeding 0.02-0.15 mm, I'm using 0.1 - 0.4 mm/rev;
    3. Depth 0.1-3 mm, I typically use 0.25 mm.
    Maybe I should also try 0.5 mm depth?..
  4. #19
    Mar 2014
    South of Adelaide
    550
    More depth of cut will help with chip breaking. try .75mm
  5. #20
    Oct 2018
    Chandler, AZ
    44
    33
    Gentlemen, thank you for your inputs. No birds nesting on the lathe anymore!
  6. #21
    Oct 2018
    Chandler, AZ
    44
    33
    Welcome newborn baby-ball! It's diameter is 25mm, two dodecs inside
  7. #22
    Oct 2018
    Chandler, AZ
    44
    33
    Here is a new puzzle - the nut in a nut. Aluminum and brass.
  1. Balls!
    By sacc51 in forum METALWORK GENERAL
    Last Post: 19th May 2015, 02:36 PM
  2. little bearing balls needed
    By old_picker in forum METALWORK GENERAL
    Last Post: 31st Dec 2013, 10:51 PM
  3. Solid Brass Balls
    By Scott in forum METALWORK GENERAL
    Last Post: 11th Oct 2012, 08:49 AM
  4. Need some pins machined up
    By Acco in forum METALWORK GENERAL
    Last Post: 13th Apr 2012, 09:57 PM
  5. Robot with balls
    Last Post: 3rd Jun 2011, 11:33 PM
