Results 16 to 17 of 17
Thread: Three major projects under way
24th Nov 2018, 12:38 AM #16Most Valued Member
- 5,945
A lot cheaper than I thought it would be. Being 8 litres capacity, it should be able to run a couple of 75mm X 200 rams.
11th Dec 2018, 10:04 PM #17Diamond Member
- N.W.Tasmania
- 1,407
I am no hydraulic expert but my understanding is that most tractor hydraulic systems run around 3000 PSI, while Enerpack style cylinders are rated for around 10,000PSI, like the pump that has been linked to. I think that you would have plenty of oil delivery, but only around 1/3 the pressure. This may not be a problem, especially if you only plan to work on thinner materials.
Some of my projects
By bts in forum METALWORK PROJECTSReplies: 3Last Post: 20th Sep 2018, 08:46 PM -
Projects Blogs FAQ .. Projects Blogs FAQ .. It's deja-vu all over again
By Ron Dunn in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 0Last Post: 24th May 2008, 10:18 AM -
First projects
By Grahame Collins in forum METALWORK GENERALReplies: 9Last Post: 15th Jul 2007, 09:59 PM
