Results 1 to 15 of 26
Thread: Belt Grinder
31st Aug 2018, 12:31 PM #1Most Valued Member
- 4,258
Belt Grinder
I started on this project some months ago and have got back into it.
All made from hot roll steel.
Its going to have a a VFD/motor belt driven shaft and a flex (?) coupling to another shaft to run disc sander on other side of of grinding station...same as the blue one on here somewhere.
I wont be making the wheels..i bought them
31st Aug 2018, 12:50 PM #2Most Valued Member
Nice work on the linisher, should work a treat
Is the drill press a bit awkward to use down low like that
Also your shed looks a bit like mine
31st Aug 2018, 03:13 PM #3Most Valued Member
- 4,258
You supposed to be looking at the belt grinder ...not my messy shed nor the stuff I will get around to restoring ..one day
running out of room..lol
She and I was talking last night...but I wasnt listening as I should have, but this morning I realised I heard her say she wants an outside entertaining area...I am now thinking about how we can come to an arrangement where she gets her outside entertainment area and i get a addon bay (or maybe 2 even??) to my shed
31st Aug 2018, 06:53 PM #4Senior Member
- Dec 2013
- 201
eskimo,
Nice looking grinder project, but what makes me most happy about your post, like Kryn, is that there is someone else with a shed as untidy and as full of stuff as mine!
I reckon you are on the right track with the deal for the add ons. I'm waiting for a similar opportunity myself. Good luck.
Graham.
2nd Sep 2018, 06:19 PM #5
Its all in there somewhere.... just keep looking!!
Looks like it will be better built then most of the stuff u see getting around the traps.Frisky wife, happy life. Then I woke up. Oh well it was fun while it lasted.From an early age my father taught me to wear welding gloves . "Its not to protect your hands son, its to put out the fire when u set yourself alight".
17th Sep 2018, 04:27 PM #6Member
- Nov 2016
- Gulfview Heights, Adelaide
- 83
Where do you buy the wheels for a project like this? What size are they ?
thanks
paul
17th Sep 2018, 08:14 PM #7
I would have thought that a foot of 50 to 70 mm diameter plastic bar would allow you to make them easily enough, and cheaper than buying them.Best Regards:
17th Sep 2018, 10:46 PM #8Banned
- Aug 2018
- 18
As long as it's not a work wheel, Acetal or aluminium would do the job. Acetal will get too hot and melt and aluminium has no give, rubber wheels are really the only alternative for a work wheel.
18th Sep 2018, 03:20 AM #9
Hi Tohot,
I hadn't realised that you were working against a wheel, I had assumed a flat bed plate. Sorry !Best Regards:
18th Sep 2018, 09:35 AM #10
People do both use the wheel for say hollow grinding a knife blade. Or use a flat platen. These style of grinders usually have interchangeable arms. That is what the large square socket is for.
28th Apr 2019, 05:17 PM #11Most Valued Member
- 4,258
Its a WIP...but still coming along
I have put a coupling in so that I can drive a faceplate on the side. The coupling will allow for easier belt changes. Need a bit moe shaft for the faceplate.
28th Apr 2019, 06:41 PM #12Golden Member
- Jul 2011
- 837
[QUOTE=eskimo;1949692]Its a WIP...but still coming along
/QUOTE]
What does the rest of the stand look like? I am currently obsessing about machine stands.
28th Apr 2019, 07:00 PM #13Most Valued Member
- 4,258
[QUOTE=lamestllama;1949696]A cabinet that came with the Darex's
Doors on the other side.
28th Apr 2019, 07:18 PM #14Diamond Member
- N.W.Tasmania
- 1,407
Nice looking work Eskimo, and you haven't held back on the steel sections either. The lightest bits look like about 16mm in thickness, you will need to assemble it where you plan to install it unless you have a Franner or a Hyster to move it about.
A great young YouTuber, Jeremy Schmidt, has produced an outstanding looking machine, and if you are unfamiliar with his work, he is definitely well worth a look. I realise that you have yours well under way, but you may pick up an idea somewhere along the way, either in the original build video, or some of the subsequent videos featuring some modifications and additional accessories that he has come up with. Congratulations again on your work, a link to JS's original build follows. https://www.youtube.com/watch?v=a_RlL1O-bK4
28th Apr 2019, 07:38 PM #15Most Valued Member
- 4,258
Belt grinder build.
By onanonanon in forum METALWORK GENERALReplies: 3Last Post: 4th Jun 2018, 12:48 PM -
Twin belt belt grinder.
By onanonanon in forum METALWORK GENERALReplies: 6Last Post: 18th May 2018, 03:52 PM -
Belt grinder/linisher
By China in forum METALWORK GENERALReplies: 14Last Post: 2nd Jan 2018, 10:33 AM -
Help me design a Metric belt grinder
By MasterSpoon in forum METALWORK GENERALReplies: 23Last Post: 12th Sep 2016, 08:46 AM -
belts for belt grinder
By eskimo in forum METALWORK GENERALReplies: 19Last Post: 20th Jun 2016, 09:23 AM
