Results 16 to 26 of 26
Thread: Belt Grinder
28th Apr 2019, 09:01 PM #16Diamond Member
- N.W.Tasmania
- 1,407
I wasn't thinking that you would want to make that change, with yours so far down the construction journey, but there might be some ideas that you can incorporate without starting over again with some of the accessory tables for instance. With your machined all over and heavy sections with no welding, warping out of shape should not be an issue for you. I look forward to the conclusion of your project, and the support cabinet looks the part too, Good luck with it all
28th Apr 2019, 09:54 PM #17Most Valued Member
- 4,255
[QUOTE=Ropetangler;1949719]I wasn't thinking that you would want to make that change, with yours so far down the construction journey, but there might be some ideas that you can incorporate without starting over again with some of the accessory tables for instance. With your machined all over and heavy sections with no welding, warping out of shape should not be an issue for you. I look forward to the conclusion of your project, and the support cabinet looks the part too, Good luck with it all[/QUOT
accesory tables...gee I am concerned as to whether or not this is going to work as planned or intended at this stage....but yeah i will pinch ideas as required...i am not concerned about about using others brains...saves mine from getting a headache
19th May 2019, 06:45 PM #18Most Valued Member
- 4,255
Another thing I learned over the last few days is that I cant spray paint as well as I once could. I sprayed mum n dads cars and all of mine when i was a lot younger....and a lot better than this.
But i reckon this still looks good...in dim light
19th May 2019, 07:34 PM #19Diamond Member
- N.W.Tasmania
- 1,407
19th May 2019, 09:17 PM #20Banned
- Aug 2015
- QLD
- 735
19th May 2019, 09:29 PM #21Most Valued Member
- 4,255
19th May 2019, 09:31 PM #22Most Valued Member
- 4,255
25th May 2019, 07:08 PM #23Senior Member
- Apr 2014
- 134
belt grinder
eskimo
where did you get the plans or did you design it
steve
26th May 2019, 11:13 AM #24Most Valued Member
- 4,255
found it on the net...and change the tracking and tension arm supports to mimic the newer version of KMG Belt Grinders. I googled KMG images saved and scaled and copied as best I could...and all worked out okay
belt sander KMG.pdf
google KMG spring dimensions and you will find them on another forum..but I just used what I had as it was close...and although a bit heavier/harder I moved backwards to supports to prevent it being so harsh a movement on the tension arm.
26th May 2019, 06:13 PM #25Senior Member
- Apr 2014
- 134
belt grinder
thanks eskimo
steve
26th May 2019, 08:45 PM #26Most Valued Member
- 5,945
Thanks for the WIP report and the link to where you got the ideas from.
Belt grinder build.
By onanonanon in forum METALWORK GENERALReplies: 3Last Post: 4th Jun 2018, 12:48 PM -
Twin belt belt grinder.
By onanonanon in forum METALWORK GENERALReplies: 6Last Post: 18th May 2018, 03:52 PM -
Belt grinder/linisher
By China in forum METALWORK GENERALReplies: 14Last Post: 2nd Jan 2018, 10:33 AM -
Help me design a Metric belt grinder
By MasterSpoon in forum METALWORK GENERALReplies: 23Last Post: 12th Sep 2016, 08:46 AM -
belts for belt grinder
By eskimo in forum METALWORK GENERALReplies: 19Last Post: 20th Jun 2016, 09:23 AM
