Results 1 to 12 of 12
Thread: Brake Drum Heater
4th Aug 2018, 09:11 AM #1
Brake Drum Heater
G’day everyone I’m in the middle of a heater build for my shed I’m wondering if anyone has any experience with flue size? I’m thinking of using about a 6 1/2”. Any help would be awesome thanks. I’ve attached some photos for a reference too.
4th Aug 2018, 03:14 PM #2Most Valued Member
Nice work.
You may need to experiment with flue size. I built a similar "camp coonara" for camping out of couple lpg cylinders. I started off with 3" exhaust but ended up going to 2-1/2" as i was loosing alot of heat out through the flue.
While yours will be bigger and your flue maybe longer, you may find 6" a bit too big. If you dont have any spare material to experiment with then probably 6" would be the best guess. You can always add a damper on the flue if you have to.
You dont want to stuff around too much as the flue was the single most expensive part of my heater.
4th Aug 2018, 04:02 PM #3
Thanks, I’m thinking I will add a damper just in case.
https://doilygrunge.weebly.com
6th Aug 2018, 02:59 AM #4
I wondered where those old brake drums went
Nice idea !Best Regards:
7th Aug 2018, 04:33 PM #5Most Valued Member
- 2,651
Pretty sure my shed heater has a 5" flue.
The heater itself is made from an old 45kg LPG bottle.
I didn't put a damper in the chimney but in hindsight it would have been a good idea.
I did put an inlet damper on it though. Here's a dodgy photo with the door open from when I was stress relieving some bars from a cast iron grate for scraping practice.
25th Aug 2018, 07:23 PM #6
Finished the heater here is the finished product. Ended up going 6” flue with damper.
25th Aug 2018, 08:29 PM #7
Looks very professional. With all the black I can’t see if it has a door or just a opening.
25th Aug 2018, 08:35 PM #8Most Valued Member
Nice work. I think the door is at the top where the handle comes out. I think you rotate that handle to hinge open the top half plate.
25th Aug 2018, 08:37 PM #9
Yeh the door is on a swing hinge at the top
25th Aug 2018, 09:04 PM #10
Couple more pics of the heater
25th Aug 2018, 09:06 PM #11
Ok the steel band around the middle was what was throwing me off in the first photo.
5th Sep 2018, 10:32 PM #12
G’day I’ve made an instructable on how to make the above brake drum heater. Thought it might be helpful to anyone wanting to make one. Any tips or ideas would be much appreciated.
https://www.instructables.com/id/Bra...tbelly-Heater/
factory workshop heater wildcat 410 lp gas heater
By dodge at4 in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 19th May 2017, 11:38 AM -
brake drum forge
By morrisman in forum THE SMITHYReplies: 5Last Post: 26th Nov 2013, 10:20 PM -
Petrol fumes in old 44 gal. drum
By Ratbag in forum METALWORK GENERALReplies: 48Last Post: 24th Sep 2012, 01:23 PM -
Truck Brake Drum Shed Heater
By Big Shed in forum METALWORK GENERALReplies: 12Last Post: 16th Jun 2011, 09:27 PM
