Results 1 to 10 of 10
    Sep 2011
    Ballarat
    65
    3,103
    Default 'Simple Indexer' for the lathe.
    I recently needed to do some indexing on my lathe and an indexing mechanism had been on my list for an awful long time.
    I will as usual apologise for the laziness of my work but I 'was' in a hurry and I used what was on hand.
    I have to say it worked very well.
    Phil
    Lathe indexer28.JPG Lathe indexer27.JPG Lathe indexer4.jpg Lathe indexer5.jpg Lathe indexer10.jpg Lathe indexer29.JPG Lathe indexer30.JPG Lathe indexer14.jpg Lathe indexer17.jpgLathe indexer21.jpg Lathe indexer20.jpg
    May 2011
    Murray Bridge S Aust.
    5,959
    I like the KISS principle, Keep It simple Sir, and can't get any simpler that what you've done.
    Top marks for enginuety.
    6,475
    Hi Phil,
    Very nicely done I like that, a lot.
    Jul 2008
    near Warragul, Victoria
    3,726
    That's a well thought out gadget ! Sorry if I missed something but can you lock the lathe spindle so that it can't move and upset the work in progress ?
    Sep 2011
    Ballarat
    65
    3,103
    Hi MM
    my lathe doesn't have a way of locking the spindle but the indexer does both. It does part rotations of the chuck using the selected gear, depending on how many divisions on whatever it is I might need to do and when the detent is engaged, it stops the chuck from rotating.
    The job I built it for was the little pinion gear(//metalworkforums.com/f303/t202...79#post1936579) which, being so small it needed a definite lock as small rotation was a big rotation cutting the teeth. I had 8 teeth to cut on a 6 mm diameter blank. I even had to put my glasses on.
    Phil
    Apr 2008
    Canberra
    805
    Nice build Phil - as discussed over PM its one I intend on copying!
    Re spindle locking - I wonder if there is a way we could use the lathes brake to do this? Install some sort of a hand brake lever maybe.
    Sep 2011
    Ballarat
    65
    3,103
    Quote Originally Posted by 19brendan81 View Post
    Hi Brendan
    After indexing and while cutting, I stuck my foot on the brake as a bit of insurance, even though the detent did the job due to it being directly attached to the spindle.
    Phil
    Feb 2018
    Florida, USA
    20
    Phil
    How do you mount on the other end? The work piece?
    Nelson
    Sep 2011
    Ballarat
    65
    3,103
    Quote Originally Posted by Nrcollar View Post
    Phil
    Nelson
    Hi Nelson
    the job I built it for was the little pinion gear I had to make. I put the material into the chuck of the lathe. With the indexer at the back (extreme left) of the lathe locating into the appropriate change gear mounted into headstock spindle using the collet, there becomes a direct connection to the lathe chuck for indexing via the gears teeth.
    Phil
    Feb 2018
    Florida, USA
    20
    Phil
    I see you use your chuck to hold the work piece. Very nice job. I made one similar to that, I use on my South Bend.
    Thanks for your response
    Nelson
  1. What is this ? Lathe bed indexer or something else ?
    By MasterSpoon in forum METALWORK GENERAL
    Last Post: 6th Dec 2017, 08:25 PM
  2. Lathe Indexer for Hercus 260
    By jack620 in forum METALWORK PROJECTS
    Last Post: 18th Sep 2017, 08:14 AM
  3. So you need a simple slot in steel and you just have a metal lathe.
    By aametalmaster in forum METALWORK GENERAL
    Last Post: 1st Apr 2014, 09:18 AM
  4. simple indexer design
    Last Post: 9th Feb 2011, 12:18 PM
  5. Simple Lathe Tool Centre Height Gauge
    Last Post: 14th Jan 2011, 05:17 PM
