Results 1 to 8 of 8
Thread: PM Research 2A
    Oct 2011
    Sydney, NSW
    1,249
    Default PM Research 2A
    Hi,
    Just finished a PM Research 2A Oscillating engine kit. You can see in one of the photo's I got a bit distracted and drilled a hole through the standard. Fixed it up with a mixture of aluminium swarf (its a aluminium casting) and epoxy glue. Runs on air.
    Ben.
    Nov 2007
    melbourne australia
    3,228
    Any plans to make a boiler and run it one steam?
    Oct 2011
    Sydney, NSW
    1,249
    I'm looking into buying a pre-made boiler. My soldering skills are pretty terrible.
    Ben.
    Oct 2012
    Mullaloo WA
    80
    An alternative to your solution is Devcon product called Fasmetal, it is an aluminium epoxy product used the refrigeration industry for repairing aluminium evaporators, when cured it looks just like aluminium and can be filed, drilled etc.
    Jan 2016
    Wodonga Vic
    38
    633
    I must have been really "distracted" when I drilled and counter-bored this hole in my little oscillating engine:P
    Managed to save the part by turning a brass plug and soft soldering it in place then re-drilling and counter-boring in the correct location.
    Ben.
    6,439
    Hi Ben,
    Nice fix !
    Seems I'm not the only one to drill holes where I shouldn't.
    Jan 2016
    Wodonga Vic
    38
    633
    Fixing my mistakes are some of my proudest and challenging accomplishments
    Jul 2006
    Athelstone, SA 5076
    4,255
    Quote Originally Posted by colnjulia View Post
    good luck with that...never ever seen any thing repair a leaking evaporator long term...seen some very short term fixes tho which can not be seen a repair!!
    Unless approved by ARC (ie the Australian Govt) a temporary fix is illegal
  1. Replies: 1
    Last Post: 4th Jul 2017, 09:32 AM
