Results 16 to 24 of 24
14th Jun 2018, 08:19 PM #16Most Valued Member
- 4,258
Roughly 28mm
14th Jun 2018, 08:24 PM #17Most Valued Member
Yea thats a fair way. Makes it impossible to make small balls let alone concave or coveing.
I would make 2 new holes if using an existing hole looks terrible.
15th Jun 2018, 06:04 PM #18Most Valued Member
- Healesville
- 2,129
https://www.youtube.com/watch?v=nWiKvNDTjB4
cheers, shed
1st Jul 2018, 09:01 PM #19Most Valued Member
- 4,258
Still working on it.....winter gardening etc etc and generally to cold in the shed etc etc has slowed progress a tad.
At this stage i will be taking Kryn's advice of machining base and plate so i achieve a reasonable height of inserts....if it fits!!!!
6th Jul 2018, 11:23 AM #20Most Valued Member
- 4,258
hooray..it works
The two bigger holes in the base of ball turner are for weight reduction..aka holes that were sacrificed to gain extra height of insert holder
I took some off the base top and bottom which allowed top section to come down giving good clearance for decent size balls. And I didnt have to drill holes.
This is the plate that the ball turner bolt onto....which uses existing top slide fastening holes. The threaded hole in the RH corner is for the CS socket head screw to screw in when not in use.
The one on the handle varies from 29.56 - 30.73mm...slightly out of round as I had no idea on how to use it...but I now know where I went wrong..which might help next time..lol.I am supprised as to how smooth it is to use. Probably the taper roller bearing...which reminds me I must pull it apart and grease it...I only oiled it when I put it together.
6th Jul 2018, 02:58 PM #21Most Valued Member
Nice to see that it's working. Where did you go wrong to get the ball out of round, just so we know not to suffer the same
mistakeexperience?
6th Jul 2018, 04:38 PM #22Most Valued Member
- 4,258
I went past centreline of chuck...i did only eyeball it
The one I made for waldown DP tablelock is only 0.09mm outoff round...good enough for me.
6th Jul 2018, 07:24 PM #23Most Valued Member
.09, Not bad for an eyeball. Nice work on the ball turner too.
6th Jul 2018, 08:20 PM #24Most Valued Member
- 4,258
Help me finish my traytop
By Bryan in forum TRAILERS & OTHER FABRICATED STUFFReplies: 47Last Post: 6th Aug 2015, 11:21 PM -
What finish is that?
By neksmerj in forum METALWORK GENERALReplies: 1Last Post: 24th May 2015, 09:18 PM -
Threads on finishing, finish, good finish
By steamingbill in forum METALWORK GENERALReplies: 17Last Post: 20th Jan 2014, 06:53 PM -
Rough finish
By th62 in forum METALWORK GENERALReplies: 16Last Post: 19th Jun 2013, 08:19 PM -
Finish on steel?
By Schtoo in forum METALWORK GENERALReplies: 7Last Post: 23rd Jun 2005, 10:33 PM
