Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Jul 2006
    Athelstone, SA 5076
    4,258
    Roughly 28mm
  2. #17
    Aug 2011
    4,779
    Yea thats a fair way. Makes it impossible to make small balls let alone concave or coveing.
    I would make 2 new holes if using an existing hole looks terrible.
  3. #18
    Apr 2012
    Healesville
    2,129
  4. #19
    Jul 2006
    Athelstone, SA 5076
    4,258
    Still working on it.....winter gardening etc etc and generally to cold in the shed etc etc has slowed progress a tad.
    At this stage i will be taking Kryn's advice of machining base and plate so i achieve a reasonable height of inserts....if it fits!!!!
  5. #20
    Jul 2006
    Athelstone, SA 5076
    4,258
    hooray..it works
    The two bigger holes in the base of ball turner are for weight reduction..aka holes that were sacrificed to gain extra height of insert holder
    I took some off the base top and bottom which allowed top section to come down giving good clearance for decent size balls. And I didnt have to drill holes.
    This is the plate that the ball turner bolt onto....which uses existing top slide fastening holes. The threaded hole in the RH corner is for the CS socket head screw to screw in when not in use.
    The one on the handle varies from 29.56 - 30.73mm...slightly out of round as I had no idea on how to use it...but I now know where I went wrong..which might help next time..lol.I am supprised as to how smooth it is to use. Probably the taper roller bearing...which reminds me I must pull it apart and grease it...I only oiled it when I put it together.
  6. #21
    May 2011
    Murray Bridge S Aust.
    5,959
    Nice to see that it's working. Where did you go wrong to get the ball out of round, just so we know not to suffer the same mistake experience?
  7. #22
    Jul 2006
    Athelstone, SA 5076
    4,258
    I went past centreline of chuck...i did only eyeball it
    The one I made for waldown DP tablelock is only 0.09mm outoff round...good enough for me.
  8. #23
    May 2011
    5,959
    .09, Not bad for an eyeball. Nice work on the ball turner too.
  9. #24
    Jul 2006
    Athelstone, SA 5076
    4,258
    That was the second ball that i took more care doing
  1. Help me finish my traytop
    By Bryan in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 6th Aug 2015, 11:21 PM
  2. What finish is that?
    Last Post: 24th May 2015, 09:18 PM
  3. Threads on finishing, finish, good finish
    Last Post: 20th Jan 2014, 06:53 PM
  4. Rough finish
    By th62 in forum METALWORK GENERAL
    Last Post: 19th Jun 2013, 08:19 PM
  5. Finish on steel?
    By Schtoo in forum METALWORK GENERAL
    Last Post: 23rd Jun 2005, 10:33 PM
