Results 121 to 125 of 125
Thread: Hydraulic Log Splitter WIP
17th Oct 2018, 05:06 PM #121Most Valued Member
Whats a spud, other than a slang work for a potato?
17th Oct 2018, 08:29 PM #122Most Valued Member
- Healesville
- 2,129
20th Oct 2018, 08:54 PM #123Most Valued Member
OH I see.
1st Nov 2018, 12:35 PM #124Intermediate Member
- Feb 2009
- Tasmania
- 43
.... or
with Bob The Builder of course!
15th Nov 2018, 06:24 PM #125Most Valued Member
Nearly finished this project. Just a few little things here and there.
One thing i had been thinking of is a 3 way splitting wedge. Given the typical size of logs i bring home and the size of my wood heater, i often find i split logs into 3 pieces, a half and 2 quarters gives a good selection of sizes.
So figured i would attempt to improve my splitting efficiency and do it in one go.
Im still undecided if i will like a 3 way wedge but only one way to find out. Its removable so if i dont find it very usable i can turf it.
Couple of pics...
Last pic shows me holding a piece of angle iron to show how it will look. I have this setup on the single wedge and it works well.
Obviously it will be fulling seam welded. Its only tacked atm.
Also the main splitting wedge still needs a tip welded to finish the wedge. Ill weld a piece of solid square and either angle grind it or mill it to the required angle.
Edit: ultimately this insert will be through bolted with 2 x m12 bolts above the angle iron wedge
Log splitter Advice needed
By simonl in forum METALWORK GENERALReplies: 45Last Post: 1st May 2018, 07:46 PM -
Extraordinary Hydraulic Wood Splitter
By Oldneweng in forum GENERAL DISCUSSION / OFF TOPICReplies: 29Last Post: 28th Aug 2017, 10:51 PM -
Firewood Splitter Modifications
By Oldneweng in forum TRAILERS & OTHER FABRICATED STUFFReplies: 45Last Post: 1st Aug 2017, 05:56 PM -
Hydraulic ram
By GSRocket in forum METALWORK GENERALReplies: 8Last Post: 6th Oct 2012, 10:19 AM -
By Geoff Dean in forum METALWORK GENERALReplies: 8Last Post: 15th Apr 2008, 12:01 AM
