Results 1 to 15 of 19
Thread: bahco adjustable spanner
23rd Apr 2018, 04:48 PM #1Most Valued Member
- 4,255
I have a Bacho 8073 (not chinese copy which work in reverse and are a real pain in the backside) that has lost its bolt which holds the thumb thingy in situ. Does any member have one that can tell me thread size.
The thread is quite deep into the shifter and its impossible to measure...well i cant anyways.
They want a small fortune for a replacement.
23rd Apr 2018, 06:42 PM #2Member
- Oct 2017
- Lismore, NSW
- 58
Eskimo,
I have a couple of Bacho 0673 shifters that are 1967 models & they have a thread that measures Ø7.05mm OD x 0.95 pitch.
Hope this helps.
Don.
23rd Apr 2018, 08:07 PM #3Intermediate Member
- Feb 2018
- Loxton
- 54
- 37
Firstly Bahco shifters don't work in reverse, they work the correct way and all the others are backwards I have heaps of Their shifters.
The 8073 is 7mm diameter, I don't have a pitch gauge and normally just check with another tap, the finest metric tap I have is 0.8 and it is finer than that. Measuring across 10 threads with the vernier I get 6.5mm, so 0.65 I would say.
Cheers Andrew
24th Apr 2018, 12:37 PM #4Most Valued Member
- 4,255
Andrew...I did say "Chinese copies"...
Picture below shows Bahco 8073 made in Sweden...top adjustable is also named Bahco not made anywhere as it doesnt say ...check the thumb screw against your made in Sweden Bacho's and you will see that its guide threads (if thats what they're called) are angled differently, and therefore must operate in reverse...I think I saw these reverse operating Bahco's when I was last in Total Tools
the white writing on the bottom one is what I thought it might be
Thanks Don and Andrew for those thread sizes
24th Apr 2018, 02:09 PM #5Pink 10EE owner
- 6,216
You can still use it for it's secondary purpose. A hammer.
24th Apr 2018, 07:26 PM #6Intermediate Member
- Feb 2018
- Loxton
- 54
- 37
So as they say you learn something everyday! I have had Bahco shifters for 30 years and have only just realised that they have screws that go opposite ways. However I also learned that it doesn't matter where they were made as I have made in Sweden ones going opposite directions.
The top 4 are all marked made in Sweden, the top 2 go one way, the next 2 the other. The bottom one is Bahco with no country of manufacture marked and goes the same way as the large Made in Sweden ones? So there you go.
I won't even start on my Bahco Multi grips with a shifter adjuster and which way they operate
Cheers Andrew
24th Apr 2018, 09:11 PM #7Most Valued Member
- 4,255
So what i thought was a chinese copy may not be a chinese copy then. Why would they do that...change screw so direction of sliding jaw works in reverse. Dont they understand how one gets used to the way things should work and expect all tools of same type to do exactly that....i hate it when they go the other way...even to the point that i gave away the ones i didnt want cos of this reason.
24th Apr 2018, 09:13 PM #8Most Valued Member
- 4,255
25th Apr 2018, 10:31 AM #9Intermediate Member
- Feb 2018
- Loxton
- 54
- 37
25th Apr 2018, 02:22 PM #10Most Valued Member
- 4,255
The .9 wouldnt go...
38tpi was the closest I could get to 0.65 and which I thought might "reform" to 0.65 and which it did...but to 0.75
we were somewhere near it..
the 38 will hold it for now...lol.
thanks Guys for your assistance.
26th Apr 2018, 01:55 AM #11Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
bacho invented shifters
so all the others are reverse.
ill have a look
26th Apr 2018, 04:56 AM #12Most Valued Member
like AJ, I also have a large Bacho that adjusts one way and a small one that adjusts the other way. Is it possible there’s some logic to that we are missing?
26th Apr 2018, 08:35 AM #13Golden Member
- Jun 2004
- Kyabram. Vic
- 632
1 style for left handers and the other for right handers.
Ken
26th Apr 2018, 12:05 PM #14.
- 6,458
More Confusion.
Ken's suggestion of handedness made me look for clues in the 1965 BAHCO catalogue I just happen to have. There is no mention of the left and right handed adjusting knurls but both are pictured. My oldest shifter is a 6" 970 with the marking " AB BAHCO STOCKHOLM ". It has a right hand knurl. Of the eight shifters in my collection, three are right handed.
BT
26th Apr 2018, 05:26 PM #15Most Valued Member
- 4,255
[QUOTE=Toggy;1934346]1 style for left handers and the other for right handers.
Ken[/QUote
cant beat logic
So this begs the question: why do you only see one way from any one manufacturer in a store... all new Bahco's i see now are left and from Rothenbeger all will be right....in the same store...why dont you see both from same maker?
never seen a left Rothenberger...nor a sidchrome if i recall correctly....even my stainless steel NZ made Sea Spanner is right...also my trojan and other cheapie are right
Mmm came across a 450mm bahco made in sweden in my tool chest ...which is left...i give up.
Spanner sizes
By DSEL74 in forum METALWORK GENERALReplies: 45Last Post: 31st May 2018, 12:26 AM -
L-00 spindle spanner
By morrisman in forum METALWORK GENERALReplies: 10Last Post: 11th Jun 2016, 01:49 AM -
NT 30 spindle spanner
By Dave J in forum METALWORK GENERALReplies: 26Last Post: 27th Sep 2012, 06:22 PM -
Overkill on a Pin Spanner
By Abratool in forum METALWORK GENERALReplies: 44Last Post: 1st May 2012, 02:21 PM -
Spline Spanner
By Sterob in forum METALWORK GENERALReplies: 7Last Post: 18th Sep 2007, 08:01 PM
