Results 1 to 4 of 4
Thread: LARGE press frame
5th Mar 2018, 12:48 AM #1Most Valued Member
LARGE press frame
I've been asked to make some sheet metal wheel barrow trays that need curved/rolled bottoms, in leiu of straight sharp folds.
The reason I've been asked to make them, is that a Kelso barrow only lasts about 3 months, and the tray's worn out, the frames last about 6 months as do the bearings in the wheels.
To make these, I'm looking at making a press similar to a garage press, but 1200 wide inside, it will have 2 X 20 tonne jacks supplying the downward pressure. Does anyone have a press similar in size, that would be able to give me the material size for the uprights, and cross members both top jack holding and bottom rails that are pressed against. Was thinking something like 150 X 75 Channel forming an I, for the top rail, and the same for the bottom rails, with 100 X 100 X 5mm posts for the uprights, sheet will be 2 mm thick.
I know that no-one will say that the material will be OK, which is why I'm asking if anyone has an existing purchased unit to basically work from.
5th Mar 2018, 07:36 AM #2
Kryn, I made a press, with a single 20 tonne jack, from 150 X 75 channel about 6 mm thick. I used it for the whole frame, posts, cross members and at the top I used 2 channels with a 10 mm gap between to allow the jack to be slid left or right depending on the piece that needs a bearing removed. OK I am only half of the power of yours but I think 150 X 75 would be beefy enough to be able to fold that material.
Just do it!
Kind regards Rod
6th Mar 2018, 04:51 PM #3Most Valued Member
Hi Kryn,
I think you should be fine for the uprights, since steel has sufficient tensile strength. The big question will be what is needed for the top and bottom that will enable them to withstand the forces from the 2x20T jacks without deflecting more than you are happy to accept.
If I was to have a guess, I would say that a 150x75 channel would not be rigid enough for a 1200mm span, even though the load is supplied via two jacks rather than a single so it's not a single point loading but it's also not a continuous loading either. It would also depend on the spacing of your jacks.
Maybe someone here has access to a stress modelling CAD software and can plug in some values for you?
13th Mar 2018, 11:43 PM #4Most Valued Member
Thanks Simon, thanks for reminding me. I punched in some details into the Beam Deflection Stress Calculator, in the section under Conversions and Calculations, something I submitted and forgot about.
Anyway by upping it from 150 to 200PFC over a 1400 span with 40,000kilo load and a 20,000 continuos load I get a total deflection of 2.5 mm, deflection will be a lot less because there will be 2 of them 100 mm apart and similar above, so that should be close enough for me.
Cycle Frame welding job
By OldGrain in forum WELDINGReplies: 12Last Post: 3rd May 2015, 09:53 AM -
extending frame of tandem trailer
By firstchoicecp in forum TRAILERS & OTHER FABRICATED STUFFReplies: 5Last Post: 16th Oct 2012, 05:00 PM -
boat window frame
By swart in forum METALWORK GENERALReplies: 2Last Post: 11th Sep 2009, 08:06 PM -
Motorbike frame.
By mako in forum METALWORK GENERALReplies: 2Last Post: 12th Mar 2008, 07:15 PM -
How to make a frame for a foldup bed?
By Tas_Dean in forum METALWORK GENERALReplies: 3Last Post: 21st Jul 2007, 08:58 PM
