Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Oct 2015
    melbourne
    473
    Thanks Grahame, amazed the brand is still around.
    I reckon I will turn a cheap steel ruler into a new blade.
    Your shed sounds a bit like mine...
    -russ
  2. #17
    Jun 2004
    Kyabram. Vic
    632
    Come on Grahame; show us the insides of your shed. Just so the rest of us can feel better about our own 'loose leaf' filing systems.
    Ken
  3. #18
    Nov 2017
    Adelaide
    36
    11
    I had the same thing with a Makita router. Part number has it down as a dual seal design, actual bearing is un-shielded.
    Only thing to consider is the speed rating, but any quality bearing should be fine. The cheap chinese stuff is average at best, they only just discovered how to grind balls truly round.
    https://www.washingtonpost.com/news/...=.3e519b2ca964
  4. #19
    Jan 2018
    Aldinga Beach.
    73
    148
    I had a Hitachi 9" angle grinder that simply would not stop. It lasted 30 od years before something needed done to it an that was a new switch as the old one had oxidised badly and the screws wouldn'y undo. sadly, safety concerns with switches led to a new design which would not fit the older models, that and advancing age (mine) and arthritis saw the Hitachi consigned to the bin.
    I wish some of the Makita tools I've had over the years were as good, never managed to get one to last more than six months, simply unlucky I guess.
  5. #20
    Aug 2006
    1,105
    I am personally a fan of Makita, i've never had any issues with them, I usually go for the higher end models though. Parts are easy and affordable to get if ever needed, they don't seem to change there models very often like some other brands out there who seem to update there stuff every year or so. Some of the models they have are still sold some 30 years later. They pretty much have every power tool possible so you can stick with the one brand.
  6. #21
    Jun 2016
    Sydney
    283
    I live on a farm. I have one old cast iron single-phase pump on the dam and another, identical, on the irrigation. Both pumps must be 50+ years old. They run.
    Meanwhile, we have bought and replaced a large number of modern domestic pressure pumps. The Australian brands last for a couple of years ( a bit more than the warranty period), then die.
    I was looking at buying a new electric drill, but they are either Chinese or very expensive. I commented to the (old) salesman that I still had my cast aluminium body B&D drill from the 70s. He went into raptures over it. It still runs just fine.
    Roger
  1. Angle grinder and the neighbors
    By Gestalt in forum METALWORK GENERAL
    Last Post: 11th Oct 2017, 08:17 AM
  2. 4' or 5' angle grinder
    By wodstok in forum WELDING
    Last Post: 7th Mar 2011, 06:49 PM
  3. Old Hitachi angle grinder help please
    By ptrott in forum METALWORK GENERAL
    Last Post: 30th Aug 2010, 02:37 AM
  4. Cordless angle grinder
    By Rossluck in forum WELDING
    Last Post: 10th May 2009, 03:19 PM
  5. What size angle grinder ??
    By PlanePig in forum METALWORK GENERAL
    Last Post: 29th Apr 2009, 08:55 AM
