Results 1 to 1 of 1
    Aug 2004
    Perth Western Australia
    65
    203
    Default Router Modification
    I had intended to use a fixed base router with my recently acquired Leigh dovetail jig, but found I needed to make modifications to the router handles to make it more suitable.
    The stalks I made out of aluminium, the grips are rubber bicycle handle bar grips and inside them is 22mm nylon solid rod.
    The slots in the handgrips were milled through the rubber.
    All went to plan.
    If I was to do it again I probably would reduce the rake of the handles a little.
    Mark
    I've become a tool of my tools.
  1. Trailer Chassis Modification
    By bobbydfangus in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 2nd Nov 2014, 07:34 PM
  2. Fan Modification.
    By BaronJ in forum METALWORK GENERAL
    Last Post: 17th Dec 2013, 08:38 AM
  3. Quick and easy modification
    By leroy in forum METALWORK GENERAL
    Last Post: 11th May 2013, 02:19 PM
  4. Helix Clamps - A modification
    Last Post: 31st Jan 2012, 11:08 PM
  5. Pulley Modification
    Last Post: 29th Jan 2011, 07:29 PM
