Results 1 to 10 of 10
Thread: Drip oiler glass
21st Oct 2017, 11:40 AM #1Senior Member
- Brisbane
- 143
Drip oiler glass
Hi.
Can anyone help with a supplier of glass tube for a drip oiler.. ?
Ken.
21st Oct 2017, 12:28 PM #2Philomath in training
- 6,562
What diameter do you need? I have two pieces 1 1/4" (I think) left over from when converted some oil drippers to 1" size.
21st Oct 2017, 12:31 PM #3Senior Member
- Brisbane Australia
- 122
Hi.
Try Labglass at Windorah St at Stafford.
Jim.
21st Oct 2017, 02:09 PM #4Senior Member
- Brisbane
- 143
size required is 38mm dia x 35mm high.
Cheers .. Ken.
25th Oct 2017, 07:47 PM #5Senior Member
- Sep 2008
- texas, queensland
- 248
i used polycarb or perspex not sure which in solid rod and just bored it out . then polished it with wet and dry then toothpaste didnt take long to do .
'If the enemy is in range, so are you.'
25th Oct 2017, 09:30 PM #6
glass
Remember when people used to make glass drinking cups out of beer bottles ? Back when we made stuff !
Go to your local op shop and buy some drinking glass of the correct diameter , scribe a line around the glass and heat up with metho, then cool it under the tap , takes a little practice to perfect the method.
Smooth the edges off with glass paper or a linisher and that's it . Glass looks so much better than perspex in a oiler .
25th Oct 2017, 10:10 PM #7Senior Member
- Sep 2008
- texas, queensland
- 248
mine was for a model hit and miss engine it was about 5/8" or 3/4 " diameter from memory .
19th Jul 2018, 08:06 AM #8Novice
- Feb 2018
- Florida, USA
- 20
Ken
My wife is a diabetic and takes insulin. The insulin bottles are glass a little larger than a quarter and about 1.25 tall. Cut the top and bottom off makes a nice glass cylinder that holds about .5 oz of oil.
Good luck
Nelson
20th Jul 2018, 03:03 PM #9Member
- Sep 2016
- Canberra
- 88
21st Jul 2018, 01:21 PM #10Novice
- Feb 2018
- Florida, USA
- 20
Another thing that is available almost every where is test tubes. You can buy all different sizes.
Check out this site. I think you can get any size you would want:
https://www.indigoinstruments.com/glassware/test_tubes/
Good luck and keep up on the progress.
Nelson
Drip oilers
By morrisman in forum METALWORK PROJECTSReplies: 4Last Post: 7th Jul 2016, 09:46 PM -
Need a New Myfrod Drip Tray
By wheelinround in forum METALWORK GENERALReplies: 15Last Post: 30th Jun 2016, 07:19 PM -
N.S.W. Bench and drip tray for small lathe.
By clear out in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 20th Apr 2013, 05:51 PM -
Drip or wick oilers?
By Old Hutcho in forum METALWORK GENERALReplies: 8Last Post: 9th Oct 2012, 07:44 PM -
Drip tray for lathe
By snowyskiesau in forum METALWORK GENERALReplies: 13Last Post: 4th Feb 2008, 08:23 PM
