Results 16 to 26 of 26
Thread: To Connect OR Not Connect
12th Aug 2017, 08:13 PM #16
Another method of using coolant is a mistless system. Lots of people are aware of the misting system, but the mistless system only delivers droplets of coolant fed by a lower pressure stream of compressed air. The droplets land on the work as drops. Very little coolant is required as the air helps reduce heat. I think it would be easy to move around so I only plan on making one and moving it from lathe to mill etc.
I have bought a cheap misting system with the intention of making a mistless system. The trick is to have 2 pressure regulators so the coolant container can be pressurised higher than the air stream. This allows the coolant to be fed into the air stream. I have seen a number of YouTube videos on these. Oxtools has one, but I think the video about him making it is just part of one of his former regular weekly presentations. You can generally see a 2 litre coke type bottle on his mill column.
14th Aug 2017, 04:01 PM #17Most Valued Member
Yes and no. Most people will notice most of my pics that show my hands or fingers will see I rarely have clean hands. When they are not greasy from the shed they are dirty from gardening and tending to the fruit trees and vegie patch. I rarely garden with gloves and rarely cover cuts (except at work) and I have never had any real problems. However, certains things I would never do such as open a fresh bag of dynamic lifter or other oganic fertiliser and inhale the contents with a deep breath! It's one thing to not worry about infections on open cuts wounds etc. but to dice with bacteria/fungii with your respiratory system is another thing. Plenty of super healthy people with awsome immune systems have died from infections.
Having said that, I have had coolant stay stagnant in my bandsaw resevior for months/years and it stays pretty good. I was surprised at how stable the stuff is when I first starting using coolant. Same same with the coolant in my SG.
I'm keen to learn more about this mistless system for the mill though..
14th Aug 2017, 09:14 PM #18It's one thing to not worry about infections on open cuts wounds etc. but to dice with bacteria/fungii with your respiratory system is another thing. Plenty of super healthy people with awsome immune systems have died from infections.
Ok, I just did a search for "Fogless" and came up with "Fogless Coolant System" by James Kilroy. Have a look at these.
15th Aug 2017, 08:47 AM #19Most Valued Member
Thanks Dean.
Lots of people have rugged immune systems but they still die of infection, even more so before antibiotics. Inhalation is the most effective and quickest mode of entry into the body of either chemical, biological or radiological agents.
In the case of biological agents, your lungs provide the perfect place for bugs to grow. It's warm, moist and has the fastest and direct entry into your blood stream via gas exchange in your avioli. Sure, your immune system will fight the infection by sending the white blood cells (puss) which is no big a deal with a superficial infected cut but when it's your lungs it soon becomes difficult to breathe when your lungs are filled with fluid (pneumonia).
This is why lung infections kill many more people than say an infected hand.
15th Aug 2017, 11:39 AM #20This is why lung infections kill many more people than say an infected hand.
I have an infection in my left fore finger at the moment because I stabbed it in the side of the top joint twice with the point of a needle file while cleaning out the inside of a little bit of copper tubing to be used as a wiring ferrule. This was Sunday. Last night I soaked it in some Dettol solution because the pain and stiffness was slowing down my work fitting my car stereo. Normally I would just keep squeezing etc until it opened up properly and then healed.
Anti bacterial hand etc cleaning products. Waste of time. If anyone thinks they can prevent infections using these they are dreaming, or more likely conned by marketing methods. Our world is smothered in bacteria, totally. So are we. Beneficial bacteria what's more. Why destroy them? We should be using logic and protecting against specific serious issues. Infectious diseases patients and such situations.
If you want to wear a mask for potting mix then that is up to the individual. Organic fertiliser? I have not heard that one. Is that what the package warns? This has been thru an industrial process and is supplied in a pellet form from my memory. Lots of people will warn against anything with the potential for dust, including the manufacturer, if only to prevent the risk of future litigation. When I heard about the need to wear a mask when handling potting mix etc my immediate thought was, well I have survived this long, hardly seems like it is worth the effort of bothering to protect myself now. I have probably got immunity from all the bugs now anyway.
I have never taken precautions against infection in ordinary daily actions and I have never had a serious infection of any type. I do come from good pioneer stock tho.
Everyone should take whatever precautions they feel comfortable with, but most of them are BS in my opinion. Is marketing involved? The world has gone really crazy with ridiculous mistaken beliefs. I recently read an article about a scientific study that determined that wholemeal bread was no more "nutritionally" beneficial for you than white bread. So where did that BS come from? Logic, add fibre etc and you don't add nutrients, only fibre etc. I was stunned that people are stupid enough to believe such a ridiculous thing. Where are their brains? I am always reading articles like this that just stun me. And most people rely on Farcebook for their news. Oh, hang on. I think the penny has dropped. People are very very gullible.
Logic is the main infection prevention tool I use.
16th Aug 2017, 08:30 AM #21Most Valued Member
Hi Dean,
the more we talk the more I realise I totally agree with you. I certainly not a germaphobe and you will never see any anti-bacterial kitchen wipes in our house! But, I still don't do silly things. We are a healthy house but I still make sure my chicken is cooked properly and stuff like that.
Yes, cleaning chemical companies have a lot to answer for. I really annoys me when you see that glen 20 add and they are spraying everything in the house to kill all the bad germs.
It's funny you mention the wheat thing. My wife and I stopped eating wheat and most grains about 3 months ago for that very reason. Empty calories with little nutritional value. I also steer clear of "low fat" foods. It's funny how we are an obese society yet we consume more "low fat" food than at any other time in history. Go figure!
Cheers.
16th Aug 2017, 11:54 AM #22
Ha ha, you trying to get me on my soapbox?
16th Aug 2017, 05:03 PM #23Banned
- Feb 2015
- Oz
- 73
- 459
A healthy diet is one that consists of food from all the food groups. The no sugar, no fat, no wheat, no meat, no dairy nonsense is just that that - nonsense. Unless you have a medical reason for not doing so, your diet should be a balanced one. The body needs sugar, or more importantly the brain needs sugar, it cannot function without it. Deprive the body of sugar and it will manufacture its own from protein, fat whatever.
If you are a cave man diet devotee, consider this: cave man ate whatever he could get his hands on, whatever grew from trees or from the ground and was edible he ate. He also ate animals, all of the animal, cave man wasn't so adept at hunting that he could afford to be choosy. In eating all the animal that meant, meat, fat, heart, liver, stomach, intestines, probably even ate the animals privates. Most animals were either herbivores or at least the same as us omnivores so their gut would have contained all sorts of matter, grains included. In effect cave man was an anyvore, he ate whatever was around, he had no choice.
A balanced diet includes foods from all food groups, the active word here is moderation: delete any of the food groups and you no longer have a balanced diet. We need meat, we need carbohydrates, we need leafy greens, we need brightly coloured vegetables and fruit in appropriate moderation. Sugar is a dietary requirement as is fat, grains, meat, vegetables - all in 'felicitous' moderation!
Sugar 'is' bad for you! if eaten in abundance! as is fat, red meat, grains, dairy, fruit, probably the only thing that you cannot eat too much of is vegetables. Having said that, broccoli and brussel sprouts are definitely bad for you, or at the very least should be considered to be!
Then there is the E word: Evolution. Civilised man has been evolving for over 6,000 years, modern man 200,000 years or 6,000,000 years if we include our primitive ancestors, our way of living has changed as has our methods of collecting and farming foods and animals and thus, we have little in common with first man - other than we still detest broccoli and brussel sprouts.
You can argue the length of time needed for evolution is great, but in reality evolution is a constant and sometimes rapid process sometimes achieved in a little as a few generations.
What any of this has to do with connecting or not I have no idea,but it was a good excuse to exercise the fingers.
16th Aug 2017, 05:27 PM #24
All very true except for one thing. Broccoli and brussel sprouts. Both good to eat if cooked right. Early man would not have had access to these. Amost all fruit and vegetables have changed beyond recognition since the dawn of man.
This is a discussion about using logic and knowledge to decide what is the best way to go about doing things in our lives. This is completely relevant to workshop activities.
16th Aug 2017, 05:47 PM #25Banned
- Feb 2015
- Oz
- 73
- 459
Well if cave man never had access to nor ate broccoli or brussel sprouts, I'm adopting the cave man diet. oh, and you are talking absolute nonsense, there is absolutely no way of cooking broccoli or brussel sprouts that would make them edible. Next you'll be telling me that cobbers are bad for you. Incidentally, did you know dark chocolate besides being good for you in moderation of course, is a cough suppressant that works better than cough syrups. I think I can feel a coughing fit coming on!
16th Aug 2017, 08:45 PM #26there is absolutely no way of cooking broccoli or brussel sprouts that would make them edible.
Hopefully next weekend we will send a young bull and maybe a wether to the abattoirs. Yum yum. Now if we can find someone with a nice pig to sell, or wants to go halves. Sold a steer and heifer Tuesday at the market and got a pretty good price. That will pay for the butcher and for some material to build up the driveway.
Help me Rewire A Motor From Star To Delta and To Connect the VFD in Melbourne
By thumbsucker in forum ELECTRICALSReplies: 68Last Post: 22nd Jun 2015, 09:25 PM -
Which way to connect a 3 phase motor?
By Vernonv in forum METALWORK GENERALReplies: 6Last Post: 7th Sep 2014, 07:10 PM -
Changing to quick connect fittings - TIG torch
By oohsam in forum WELDINGReplies: 3Last Post: 26th Mar 2014, 09:09 PM -
Quick connect air couplings and air pipe
By Pete F in forum METALWORK GENERALReplies: 30Last Post: 31st Mar 2012, 11:38 PM
