Results 16 to 30 of 45
  1. #16
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Until I've tried them out, I'm not making any comments on how good they will hold on a magnet chuck nor on any ideas of making more.
    Who knows, if they are any good, I might talk to one of my contacts in China about a run....
    Cheers, Joe
  2. #17
    6,480
    Hi Joe,
    Certainly a very handy tool to have, ARC Euro in the UK do square and hex ones.
  3. #18
    Aug 2010
    72
    3,105
    Hi Baron,
    that's where the idea came from or course: Stephenson blocks. John Stephenson came up with the design and licensed Arc Euro to have them made.
    That's why I called these ones 'Joe-Peter blocks' - tongue in cheek....
    Cheers, Joe
  4. #19
    6,480
    Well when you get them into production, I want one !
  5. #20
    Aug 2010
    72
    3,105
    Prototypes finished and tested.
    The relatively narrow 'lands' on the duodecagon body are indeed a little too small to hold securely ACROSS a magnetic chuck. They hold fine straddling a few magnetic poles longways, but they only sit on a single pole across the chuck. However, due to every facet having two at right angles, they turn out to be very secure when blocked in o either side. The flux lines appear to join two blocks and the duodecagon very securely. I've ground a couple of trials without problems. Photos of some 'proper' test pieces to follow. Holding the collet blocks in a milling vice will make this rock solid for milling I think.
    We attempted to just machine the 16 deg included angle for the collet taper, but the contact lines remained too narrow for our liking. So I ended up grinding them. I used a tiny but very true running 5mm diameter CBN point I have in my 50k rpm air pencil mounted in the toolpost and it worked extremely well.
    Blueing the collet contact showed almost the entire taper is contacting.
    I'm very happy with the result. But they should be made from harder material or case hardened. This steel marks too easily as it turn out.
    IMG_20170711_012404 (Large).jpg IMG_20170711_012507 (Large).jpg IMG_20170711_012554 (Large).jpg IMG_20170711_012724 (Large).jpg
    Cheers, Joe
  6. #21
    Mar 2014
    South of Adelaide
    1,227
  7. #22
    Dec 2007
    1,628
    Who wrote the description?
    Unique Joe Collet ER40 Block with Ball bear Nut--Patent Pending---
    It is our patent pending products now .
    It can have many change .
    So that you can used better ER40 collet set for many different working .
  8. #23
    6,480
    Hi Joe,
    By gum that was quick !
  9. #24
    May 2011
    Murray Bridge S Aust.
    5,959
    Cheeky blighters, Patent Pending my butt, sees it on here sends a copy to his mates over there and hey presto.
    Be nice to find out when the "Patent" was "registered"????
  10. #25
    Aug 2010
    72
    3,105
    The real story is that I applied for a development patent. I then contacted my acquaintance Felix Wu and asked him if he was interested in collaborating with me - without telling him any datails. I asked him to check the interest of his acquainted and trusted manufacturers in China, and to machining capabilities.
    I then sent him a detailed drawing for an ER40 version to get a quote.
    We negotiated a licence fee and a retail price range.
    The first samples of 5 units arrived yesterday in Melbourne.
    In extensive correspondence with me, he ordered an initial production run of 500 units to be made and ordered 500 matching ball bearing collet closing nuts.
    All at his expenses.
    So in a few weeks (when I'm back in Australia), these collect block will be exclusively available from MagPro in Melbourne.
    So no, nothing is wrong, stolen or cheeky.
    Just to explain my previous silence on the topic, I was advised not to publicise any further details until all the documentation was finalized - which happened today.
    So far, MagPro and Felix Wu is respected and reliable business and person.
    Sorry I had to leave you in the dark into now.
    Sent from my InFocus M808 using Tapatalk
    Cheers, Joe
  11. #26
    Jan 2011
    Far West Wimmera
    63
    4,049
    Ha ha, you're forgiven.
    Great stuff Joe. Whatever happened to being retired? I wondered and hoped you were behind this. It just seemed a bit too coincidental and quick to be otherwise.
  12. #27
    6,480
    Hi Joe,
    Thanks for the explanation ! I guessed as much Could do with the grammar sorting on the listing though.
    Now when do I get mine ?
  13. #28
    Apr 2013
    Toowoomba Qld
    401
    Please for the love of god put the collet in the collet nut properly then take your photos again on the Ebay listing
    You / Magpro may also want to note in the listing that the collet is not included (unless you are including one) as pictures make up part of the description and may end up with disputes or bad feedback.
    Wayne
  14. #29
    May 2011
    5,959
    Thanks for the explanation Joe, and my apologies to MagPro. Seemed a bit strange that it ran the same name as you called them.
    Glad to see they're in production.
  15. #30
    Jun 2011
    Australia east coast
    2,713
    Not trying to take anything away from you Joe, but just how can they issue a patent of any type for what is an obvious variant of a well established item?
    Good luck to you but I can't see that it's valid. I've seen a lot of bogus stuff claimed in software patents so I'm a bit sensitive about this sort of thing.
    PDW
  1. Jo Blocks
    By YBAF in forum METALWORK GENERAL
    Last Post: 12th Feb 2016, 01:07 PM
  2. 1-2-3 Blocks as Parallels?
    By simonl in forum METALWORK GENERAL
    Last Post: 10th May 2013, 08:15 PM
  3. Gauge blocks
    Last Post: 23rd Dec 2012, 11:44 AM
  4. Replies: 10
    Last Post: 6th Mar 2012, 12:28 AM
