Page 1 of 3 123 LastLast
Results 1 to 15 of 45
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Default New 'Joe-Peter' collet blocks
    I may have invented a new ER collet block design. It was my original thought, but other may well have had the same thought - and I just can't find any evidence.
    So here goes:
    I decided to make some 'Stephenson' ER collet blocks. A four-sided and a hex one. to suit ER32 collets. Only I wanted the blocks larger in cross-section than the collet nut, so I could use them on the surface grinder - directly on the magnetic chuck, rather than in a vice on the magnetic chuck.
    On a mill, however, when I thought about holding the hex block in a vice, I figured that either the sides were held in the jaws or the corners (with either a flat on the bottom or a corner). So in my mind, the corners should not be sharp. Then I figured that the corner 'breaks' could be machined to be parallel to each other to facilitate locating and holding in a vice without damage. The next thing that came to mind was "why not make the machined corners the same width as the flat?". And then it struck me: with a twelve-sided (duo-decagon) block profile, you don't need a square profiled block at all!
    I ran the idea by my friend Peter, who thinks like I do and we share equipment and shed time. We decided that we'd make two - one for each of us to evaluate and use.
    So here we go with a proof of concept:
    Raw (mystery steel - but tough) stock
    Turned to size then milled into duo-decagon shape in rotary table
    Ground flats
    Cut in half to make the two blocks
    Drilled and bored to roughly 26mm,
    then threaded for the first ER32 nut thread
    Nut attached.
    What do you think so far?
    Next step is getting the second block to this state, then boring and grinding the 16 degree tapers for collets.
    Photos coming when done - maybe later in the week.....
    Cheers, Joe
    6,475
    Nice one Joe ! I like that idea.
    Aug 2010
    72
    3,105
    Thanks Baron. I'll post how they work in use when done. The proof is in the pudding......
    I should be able to machine or grind one, two, three, four, six and twelve sided objects, plus eight-sided using V-blocks. I'll try.
    Cheers, Joe
    Jul 2016
    35
    1,522
    I think they look great, my only hesitation is in making them so wide they would be difficult to keep a hold of in shallower vices. This wpuld probably be more of an issue with er40 than 32. Look forward to more progress!
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Co-incidentally, you'd never guess what I made up yesterday...
    You probably don't need to grind the tapered bore. The collet chuck I made for my lathe is only MS bored out on the lathe and is coping quite well after many years.
    I did think about making mine big enough to clear the (ER40 = 63mm) nut but started getting into a 'where do you stop' loop. Heavier too. As my grinder chuck is only 4" wide, by the time the holder was located across the table I would not have much room left to grind. If I needed to do that I was going to get a solid bit of plate and hang that over the edge of the mag chuck so clamping was done off table and allow the workpiece to be over the chuck.
    near Rockhampton
    6,218
    Here is a 12 sided ER40 one I made back in 2010.
    Due to the small clamping surfaces it tends to move unless squashed very tight.
    Aug 2010
    72
    3,105
    Great minds think alike! Snap.
    Thanks for the warning about clamping.
    On mine, the flats are 14mm wide. I would think that's enough 'meat', but thanks nonetheless.
    Cheers, Joe
    Aug 2010
    72
    3,105
    You got to be kidding me... How's that????
    I'll see what the surface finish turns out like in the taper on this steel. Thanks for the feedback on mild steel chuck longevity.
    Cheers, Joe
    Oct 2011
    59
    6,561
    For the record -
    Flats on this one are 28mm wide.
    Aug 2010
    72
    3,105
    Nice work Michael!
    I give you 'permission' - and I suspect R.C. would too - to mill off the six edges
    Cheers, Joe
    Feb 2013
    Laidley, SE Qld
    1,039
    The big hex block gets a fair bit of use. Its a piece of 2.25" 1020 hex, the ER32 taper is turned and finger ground. The round one is made from tough mystery metal, I find it useful in the 4 jaw for cutting eccentrics.
    Jul 2006
    Athelstone, SA 5076
    4,258
    "what do I think so far" did you make me some too!?
    Aug 2010
    72
    3,105
    Thanks. We've finished them both now, but I'm away from home and can't try it or send photos until the weekend....
    Cheers, Joe
    Dec 2007
    1,628
    Are the skinny flats going to hold on a mag chuck??
    I'm predicting a small batch should be run off.
  15. #15
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by DSEL74 View Post
    he ignored my comment, so I'm guessing your prediction wont come true...lol
  1. Jo Blocks
    By YBAF in forum METALWORK GENERAL
    Last Post: 12th Feb 2016, 01:07 PM
  2. 1-2-3 Blocks as Parallels?
    By simonl in forum METALWORK GENERAL
    Last Post: 10th May 2013, 08:15 PM
  3. Gauge blocks
    Last Post: 23rd Dec 2012, 11:44 AM
  4. Replies: 10
    Last Post: 6th Mar 2012, 12:28 AM
